Form won't set Summary:Comments field in Drawing
Our title block uses a couple iProperty fields to fill information, including the multi-line Comments field. I've written a simple form that allows the user to set the Title, Author, Project Name, etc. and this all works fine. Because Inventor for some reason does not include the Summary:Comments field as a stock input in the form generator, I've made a Rule that sets the Summary:Comments field to user property "DrawingStatus", then added a field in the form that allows the user to set the DrawingStatus field.
Interestingly, this all works in the Part/Assembly environment - I can run the form and am able to set the DrawingStatus field, which correctly filters into Summary:Comments. But when I try to do the same in a DWG file, the Drawing Status input box is greyed out and the label has a line drawn through it. Any idea why the DWG environment would treat this differently? Thanks!
bradeneuropeArthur
Could you please upload your code and dwg file.
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
