Vault Addin - Check in to multiple Vaults
n_krisch
n_krisch
Hi there,
is there a way with VBA to use the Vault Addin to check in the same ipt into 2 different Vaults?
Same Server, same filename, same path...
Is it possible to accomplish it "silent" in the background or "active" with input boxes for vaultname, username and passwort?
I can only find a solution for the active (already logged in) vault, but no code to "choose" a vault.
Kind regards
Nico
bradeneuropeArthur
This is possible with the vault API.
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
