VBA editor 'Imports'
Hi
I'm trying to import regular expressions into the local VBA project for a drawing document.
Putting the `Imports` statement ahead of the only `Sub` gives the following error:
This works in the rule editor, but not here.
Does anyone know what might be wrong or have any recommendations for what to try?
bradeneuropeArthur
Imports are not used in VBA!
Use add reference in the options!
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
I knew I had to be missing something!
But is this where I add it?
I've tried calling `System.Text.RegularExpressions.Regex.IsMatch()`, but it throws this error, that `.Text` isn't defined:
I checked in that directory, and I have a System.Text.RegularExpressions.dll, but it says I can't add it as a reference..!
bradeneuropeArthur
Does this help:
https://forum.uipath.com/t/cheatsheet-system-text-regularexpressions-regex/354895
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
I don't think so. I've been using regular expressions for almost 10 years. I just need to import the library, and that mentions it glancingly, and then moves on.
