Simple Conversion - VBA To Vb.Net
isocam
isocam
Can anybody help?
I have the following Inventor VBA script that exports a sheet metal part to a "flat pattern" dwg file. It works great!!
Dim oDataIO As DataIO
Set oDataIO = oDoc.ComponentDefinition.DataIO
Dim sOut As String
sOut = "FLAT PATTERN DWG?AcadVersion=2000&OuterProfileLayer=Outer"
oDataIO.WriteDataToFile sOut, DwgFileName
Can anybody tell me if the above code needs to be converted to work using a Vb.Net AddIn?
Many thanks in advance!
Darren
Dev_rim
Hello there,
Yes you have to change a couple things. Parameters of functions should be written between "()" at VB.net
Here you go
Dim sOut As String
oDataIO.WriteDataToFile(sOut, DwgFileName)
Regards
Devrim
If my answer is solved your problem, please mark it as Solution
Freundliche Grüße / Kind Regards
