VBA Code for exporting SAT files - Help needed from someone with VBA knowledge
Message 1 of 25
We currently use a simple VBA macro to generate a DXF of a drawing to a specific folder by clicking on a button. We need the same function for creating a SAT file from an IPT (sheet metal part) and I am struggling to make this work. I know it is probably possible with Ilogic but would prefer to just add have this as the same function we have on the DXF.
This would export the IPT as a 3D model (not the flat pattern) to a specified folder and keep the original filename but as *.SAT
The code we use for the DXF export is below. If any VBA experts out there could help with some code for SAT files it would be appreciated.
Fred
Sub EXPORT()
Dim invApp As Inventor.Application
Set invApp = ThisApplication
invApp.SilentOperation = True
Dim idwDoc As Inventor.DrawingDocument
Set idwDoc = invApp.ActiveDocument
Dim dxfFile As String
dxfFile = idwDoc.FullFileName
dxfFile = "\\HKEURVAULT\Inventor Resources\DXF_FOR_LAYOUTS\" & idwDoc.DisplayName
Mid(dxfFile, Len(dxfFile) - 3) = ".dxf"
With invApp.CommandManager
Call .PostPrivateEvent(kFileNameEvent, dxfFile)
Call .StartCommand(kFileSaveCopyAsCommand)
End With
Set idwDoc = Nothing
invApp.SilentOperation = False
Set invApp = Nothing
End Sub
Replies (24)
Message 21 of 25
bradeneuropeArthur
 Public Sub ExportToSat()
        Set m_invApp = ThisApplication
        Dim oSATTrans As TranslatorAddIn
        Set oSATTrans = m_invApp.ApplicationAddIns.ItemById("{89162634-02B6-11D5-8E80-0010B541CD80}")
        If oSATTrans Is Nothing Then
        Exit Sub
        Dim oContext As TranslationContext
        Set oContext = m_invApp.TransientObjects.CreateTranslationContext
        Dim oOptions As NameValueMap
        Set oOptions = m_invApp.TransientObjects.CreateNameValueMap
        If oSATTrans.HasSaveCopyAsOptions(m_invApp.ActiveDocument, oContext, oOptions) Then
            oOptions.Value("ExportUnits") = 5
            oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
            Dim oData As DataMedium
            Set oData = m_invApp.TransientObjects.CreateDataMedium
            Dim oSatFileName As String
            oSatFileName = Replace(m_invApp.ActiveDocument.FullFileName, ".ipt", ".sat") ' ipt to sat
            On Error Resume Next
            MkDir ("\\hkeurvault\SAT_FILES\")
            Err.Clear
            oData.FileName = "\\hkeurvault\SAT_FILES\" & oSatFileName
            Call oSATTrans.SaveCopyAs(m_invApp.ActiveDocument, oContext, oOptions, oData)
    End Sub
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 22 of 25
Still same error? See attached
Message 23 of 25
bradeneuropeArthur
Sorry, but I have copied to fast.
I am working along different projects and forgot to second check it.
Hope this will work now!!
        Exit Sub
            oSatFileName = Replace(m_invApp.ActiveDocument.DisplayName, ".ipt", ".sat") ' ipt to sat
            MsgBox oSatFileName
            Err.Clear
    End Sub
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 24 of 25
Worked perfectly thanks
Please don't apologise, I really appreciate your help
Message 25 of 25
bradeneuropeArthur
Took some time, but with succes.
Your thanks are appreciated too...
if any help is required please don't hesitate.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
