VBA - Change currently active dimension style
Message 1 of 15
Hello!
I am trying to create a macro that I can run with a button, that enables the Dimension tool, and automatically sets a specific style as active, so I do not have to do it manually each time..
This code enables the Dimension tool in the drawing:
    Dim oCommandMgr As CommandManager
     oCommandMgr = ThisApplication.CommandManager
    Dim oControlDef As ControlDefinition
     oControlDef = oCommandMgr.ControlDefinitions.Item("DrawingGeneralDimensionCmd")
    Call oControlDef.Execute
	  oControlDef = oCommandMgr.ControlDefinitions.Item("DrawingNewDimensionStyleCtxCmd")
So far Its working great.. But now I would have to set the style to a specific one. Is there a way to do it via VBA?
Best regards
Replies (14)
Message 2 of 15
I managed to find the style i need, but I do not know how to activate it..
SyntaxEditor Code Snippet
doc.StylesManager.DimensionStyles(2)
Message 3 of 15
Nobody? 😞 searched for hours but couldnt find a solution on this..
Message 4 of 15
GeorgK
Sub ChangeDimStyle()
Dim oDoc As DrawingDocument
Set oDoc = ThisApplication.ActiveDocument
Dim oNewDimStyle As DimensionStyle
Set oNewDimStyle =
oDoc.StylesManager.DimensionStyles.Item("MyDimensionStyle")
Dim oGeneralDim As GeneralDimension
For Each oGeneralDim In
oDoc.ActiveSheet.DrawingDimensions.GeneralDimensions
oGeneralDim.Style = oNewDimStyle
Next
End Sub
Message 5 of 15
thanks for your reply.. I am not trying to change already placed dimensions.. I am trying to change the currently active style so i can place NEW dimensions with the style i need...
thanks!
Best regards
Igor
Message 6 of 15
Just for clarification, I would need to change the highlited setting via VBA/iLogic, once that the Dimension command is active. (activating the dimension command is already done in vba..)
Message 7 of 15
bradeneuropeArthur
Public Sub ChangeStyles()
Dim d As DrawingDocument
Set d = ThisApplication.ActiveDocument
d.StylesManager.ActiveStandardStyle.ActiveObjectDefaults.LinearDimensionStyle = d.StylesManager.Styles.Item("YOUR STYLE NAME")
d.StylesManager.ActiveStandardStyle.ActiveObjectDefaults.########### = d.StylesManager.Styles.Item("YOUR STYLE NAME")
'ETC ETC
d.Save
End Sub
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 8 of 15
Hello Braden,
Thanks for your answer.. I have already tried this, but unfortunately it does not change the dropdown in th eimage.. instead it changes the default style, thus, changing the style of all the dimensions I already placed.. What i need is a way to set the style only for the currently active command (Dimension) and have the style applied only for the dimensions I am going to place while the command is active..
Message 9 of 15
bradeneuropeArthur
for me it does.
but you need to change the necessary dimension type!!!
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 10 of 15
This is how i tried it:
place to sheets in the document. put a view on the first sheet, and one on the second sheet.
Add a linear dimension with the default style on the second sheet.
go back to sheet 1, and run this:
[code]
' Get the CommandManager object.
' Get control definition for the line command.
' Execute the command.
'Call oControlDef.Execute
Dim doc As DrawingDocument
doc = ThisApplication.ActiveDocument
doc.StylesManager.ActiveStandardStyle.ActiveObjectDefaults.LinearDimensionStyle = doc.StylesManager.DimensionStyles(2)
[/code]
Now place the linear dimension (command already activated by the script) on the view on sheet 1.
If you go to sheet 2 now, you will see that also the dimension you placed earlier using the default style has changed to the new style.
Message 11 of 15
bradeneuropeArthur
Your are right.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 12 of 15
Do you think there is a solution?
Message 13 of 15
bradeneuropeArthur
I am still investigating the issue between other issues.
I will inform you about it I a solution is found, ok?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 14 of 15
nicolas_fruhauf
Community Visitor
Community Visitor
Any news 5 years later ??....
Message 15 of 15
nanduadityas
Community Visitor
Community Visitor
Try this
ThisDrawing.ActiveDimStyle = ThisDrawing.DimStyles(0)
