Unable to create flat pattern
JelteDeJong
Mentor Mentor
JelteDeJong
Im writing a addon in c#. This addon needs to create a drawing from a part file that is active when i run the addon. It needs to create a view from a flat pattern in a idw.
below you find the relevant code. Most code is copyed from the help file and converted to c#.
Document oDoc = inv.ActiveDocument;// <-- assume this is a part document
string templatePath = inv.FileManager.GetTemplateFile(DocumentTypeEnum.kDrawingDocumentObject);
DrawingDocument oDrawDoc = (DrawingDocument)inv.Documents.Add(DocumentTypeEnum.kDrawingDocumentObject, templatePath);
Sheet oSheet = oDrawDoc.ActiveSheet;
NameValueMap oBaseViewOptions = inv.TransientObjects.CreateNameValueMap();
oBaseViewOptions.Add("SheetMetalFoldedModel", false); // <- if this is set to "true" it will work
TransientGeometry oTG = inv.TransientGeometry;
Point2d insertPoint = oTG.CreatePoint2d(15, 12);
DrawingView oFrontView = oSheet.DrawingViews.AddBaseView(
    (_Document)oDoc, insertPoint,
    1,
    ViewOrientationTypeEnum.kCurrentViewOrientation,
    DrawingViewStyleEnum.kHiddenLineDrawingViewStyle,
    null,
    oBaseViewOptions);
The line "oBaseViewOptions.Add("SheetMetalFoldedModel", false);" is the option that tells inventor to create a flat pattern. This option only fails if i set it to "false". (if i set it to "true" the code runs with out any problems but i dont get a flat pattern.)
the error message is:
System.ArgumentException: The parameter is incorrect. (Exception from HRESULT: 0x80070057 (E_INVALIDARG))
Can some one tell me what i should do different?
Jelte de Jong
Blog: hjalte.nl - github.com
JelteDeJong
I found the solution.  the "ViewOrientation" may not be set to "ViewOrientationTypeEnum.kCurrentViewOrientation". It works if i set it to "ViewOrientationTypeEnum.kDefaultViewOrientation"
Jelte de Jong
