UserInputEvents or SelectEvents? For OnSelect handling
Jef_E
Jef_E
I am tweaking my AddIn, and stumbled upon something. There are two ways to catch the event of a user selecting a object. Which one is preferred for my case?
For me catching the OnSelect Event is when the user clicks on a object. I would like to know it, to process his selection and  then show specific parameters or other things that are relevant for us. mostly partdocument, assembly documents and component occurrences are processed.
But is there a difference if I use the InteractionEvents.SelectEvents Or CommandManager.UserInputEvents it's OnSelectEvent?
Please kudo if this post was helpfull
Please accept as solution if your problem was solved
Inventor 2014 SP2
bradeneuropeArthur
Could you please provide me as text file the code regarding the selection events methods.
.CommandManager.CreateInteractionEvents.SelectEvents
For me they are not fired/working.
So I can't investigate the differences.
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Jef_E
Okay, I think i figured it out, use the createinteractionevents when you want the user to pick something as a question.
Example: addin replaces a selected item. Code runs, and there is no Item selected... ask the user to select a item and then the code proceeds.
or like it is used in this link. http://adndevblog.typepad.com/manufacturing/2013/02/pick-a-point.html
Now secondly I found something weird in the UserInputEvents.Unselect If a deselection is made, it gets caught twice the event?? Why is this?
I tested it with this code
    Private Sub User_OnUnSelect(ByVal UnSelectedEntities As Inventor.ObjectsEnumerator,
                                ByVal SelectionDevice As Inventor.SelectionDeviceEnum,
                                ByVal ModelPosition As Inventor.Point,
                                ByVal ViewPosition As Inventor.Point2d,
                                ByVal View As Inventor.View) _
                                Handles UserInputEvents.OnUnSelect
        Debug.Print(SelectionDevice.ToString)
        Debug.Print(UnSelectedEntities.Count)
    End Sub
This is the debug output when select 1 item and the unselect it.
kGraphicsWindowSelection
0
0
So what does this mean? There were 0 entities deselected twice? Huh.. that strikes me as odd or is it a bug? @johnsonshiue
Inventor 2014 SP2
bradeneuropeArthur
I can't get it to work:
What am I doing wrong:
Public WithEvents SE As Inventor.SelectEvents
SE = _InvApp.CommandManager.CreateInteractionEvents.SelectEvents
Private Sub SE_OnUnSelect(UnSelectedEntities As ObjectsEnumerator, SelectionDevice As SelectionDeviceEnum, ModelPosition As Point, ViewPosition As Point2d, View As Inventor.View) Handles SE.OnUnSelect
        MsgBox(SelectionDevice.ToString)
        MsgBox(UnSelectedEntities.Count)
    End Sub
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Jef_E
Edit: I cannot edit my post, forget about the bug, I subscribed twice to the event. Still 0 entities are unselected
@bradeneuropeArthur just follow the link I posted.
Inventor 2014 SP2
bradeneuropeArthur
@Jef_E
What does it mean for this moment?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Jef_E
That, if you want to monitor constantly what the user is selecting you should use the UserInputEvents. If you want to create a Pick function you should use the SelectEvents
Inventor 2014 SP2
