VBA can't use component occurrence as argument of a function
Message 1 of 8
 I am trying to loop trough an assembly with multiple subassemblies and parts, and I can't manage to use the componentoccurence as an argument of the recursive function LoopAssembly (oPart)
I always get:
run-time error '438'
Object dosen't support this property or method
I have also tried this by looping trough each Bomrow of a BOM, and i had the same issue when passing the Bomrow as an argument.
I would appreciate some help in this issue.
Sub InspectAssembly()
Dim oApp As AssemblyDocument
Set oApp = ThisApplication.ActiveDocument
Dim oPart As ComponentOccurrence
For Each oPart In oApp.ComponentDefinition.Occurrences
    MsgBox oPart.Name
    If oPart.SubOccurrences.Count > 0 Then LoopAssembly (oPart)
Next
End Sub
Function LoopAssembly (Asse As ComponentOccurrence)
Dim oPartfunc As ComponentOccurrence
For Each oPartfunc In Asse.SubOccurrences
     MessageBox.Show (oPartfunc.Name)
If oPartfunc.SubOccurrences.Count > 0 Then LoopAssembly (oPartfunc)
Next
End Function
Thank you
Replies (7)
Message 2 of 8
bradeneuropeArthur
For Each oPart as object In oApp.ComponentDefinition.Occurrences
    MsgBox oPart.Name
Next
End Sub
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 3 of 8
dgreatice
You forgot"End If".
MsgBox oPart.Name
Call LoopAssembly (oPart)
End If
Next
End Sub
Call LoopAssembly (oPartfunc)
End if
Next
End Function
Please use the ACCEPT AS SOLUTION or KUDOS button if my Idea helped you to solve the problem.
Autodesk Inventor Professional Certified 2014
Message 4 of 8
It doesn't work. I had to change the sintax as "For Each oPart as object" doesn't work on VBA, and used Dim oPart as Object instead of component occurence,. But the result was the same, unable to pass oPart as an argument.
Thank you
Message 5 of 8
That is not the problem. Actually you don't need to use end if, if you are just writting one line of code ahead of then.
Thank you anyway for the attention
Message 6 of 8
dgreatice
Did you see my red highlight?
When I try you code, same error are show.
Message 7 of 8
bradeneuropeArthur
Public Sub main()
Dim a As Application
Set a = ThisApplication
Dim b As AssemblyDocument
Set b = a.ActiveDocument
Call InspectAssembly(b)
End Sub
Sub InspectAssembly(oApp As AssemblyDocument)
Dim aascom As AssemblyComponentDefinition
Dim partComp As PartComponentDefinition
Set aascom = oApp.ComponentDefinition
For Each oPart In aascom.Occurrences
    MsgBox oPart.Name
    If oPart.DefinitionDocumentType = kAssemblyDocumentObject Then
    'LoopAssembly (oPart.)
    InspectAssembly (oPart.Definition.Document)
    End If
    'If oPart.SubOccurrences.Count > 0 Then
    'End If
Next
End Sub
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 8 of 8
Thank you for the tip. Using Call solved my problem.
I was trying to understand your end if reference, that my eyes didn't see  the "Call" word
This works like a charm now.
MsgBox oPart.Name
If oPart.SubOccurrences.Count > 0 Then Call LoopAssembly(oPart)
Next
End Sub
Function LoopAssembly(Asse As ComponentOccurrence)
Dim oPartfunc As Inventor.ComponentOccurrence
MsgBox (oPartfunc.Name)
If oPartfunc.SubOccurrences.Count > 0 Then Call LoopAssembly(oPartfunc)
Next
End Function
