"Object variable or With block variable not set" Please help
I've attached the part and the iLogic code (separately as a text file)
I've used the same type of code in other functions in the same iLogic rule. If I uncomment virtually anything in the "Coupling" function, the error appears. I can't understand why it's throwing errors in one particular function. Help? (please ignore my message boxes -- it's what I use to verify that the code gets to particular places)
The text of the error message:
Error in rule: Water Manicode, in document: Water Manifold.ipt
Object variable or With block variable not set.
The text of the "More Info" on the error:
System.NullReferenceException: Object variable or With block variable not set.
at Microsoft.VisualBasic.CompilerServices.Symbols.Container..ctor(Object Instance)
at Microsoft.VisualBasic.CompilerServices.NewLateBinding.LateGet(Object Instance, Type Type, String MemberName, Object[] Arguments, String[] ArgumentNames, Type[] TypeArguments, Boolean[] CopyBack)
at LmiRuleScript.Coupling(Object SupplyAndReturn, Object CompassDirections)
at LmiRuleScript.SetCouplingDiameter()
at LmiRuleScript.Main()
at Autodesk.iLogic.Exec.AppDomExec.ExecRuleInAssembly(Assembly assem)
at iLogic.RuleEvalContainer.ExecRuleEval(String execRule)
Maxim-CADman77
Seems like Coupling function does not support empty value of SupplyAndReturn variable.
Adding either of the two strings:
SupplyAndReturn = "Supply"
or
SupplyAndReturn = "Return"
(you should know which one is correct for you)
just before the line 127 seems to fix your issue.
Please vote for Inventor-Idea Text Search within Option Names
RoyWickrama_RWEI
Thanks for your posting.
When I run the rule in drawing (in the 1st-time running) I get the similar error message: but unable to fix by myself. Could you help. Sample files attached.
Inventor 2019
Vault Professional 2019
Maxim-CADman77
The IDW you've posted doesn't reference the IPT you've posted - it sks for Part1.IPT on Open.
If I use To Post.IPT instead of Part1.IPT and run the mentioned Rule (Btw there are 4 rules embedded in To Post.IDW) I get
Then 3 more dialog boxes and no errors.
PS: I've used Inventor 2019 with Update 3
RoyWickrama_RWEI
Thanks for the reply. I tried past 1:00 am and rushed to post for help. I apologize for my mistake. I re-attach the documents: Please try to help me. - Thanks.
Roy Wickrama
Maxim-CADman77
First of all judging by your InvDoc iProps you are using Inventor 2019 build 136 (I'm using Inventor 2019 build 278)
Consider installing most recent Update 2019.3.
Sure you know everything about Inventor Updating but just in case see:
https://knowledge.autodesk.com/support/inventor-products/downloads/caas/downloads/content/inventor-2...
https://knowledge.autodesk.com/support/inventor-products/learn-explore/caas/CloudHelp/cloudhelp/2019...
for more info.
There were definitely some improvements regarding iLogic between Build 136 and 278 which can lead to different behavior on your and my PC on the same dataset.
PS: You are supposed to make sure you are using software with all actual updates installed before starting to ask any questions on the forums.
