VB.NET SelectEvents Filter Problem
tdant
tdant
I've struggled with this for two days now and can't figure it out. I'm calling a form with an add-in to Inventor 2017. This form is the troublemaker:
Imports Inventor
Public Class ViewsForm
    Private m_interactionEvents As InteractionEvents
    Private m_selectEvents As SelectEvents
    Private Sub ViewsForm_Shown(sender As Object, e As EventArgs) Handles Me.Shown
        m_interactionEvents = g_inventorApplication.CommandManager.CreateInteractionEvents()
        m_interactionEvents.StatusBarText() = "Select part views to label"
        m_selectEvents = m_interactionEvents.SelectEvents
        m_selectEvents.AddSelectionFilter(SelectionFilterEnum.kAllEntitiesFilter)
        m_selectEvents.SingleSelectEnabled = False
        m_interactionEvents.Start()
    End Sub
    Private Sub cmdOK_Click(sender As Object, e As EventArgs) Handles cmdOK.Click
        Dim selectedViews As New Collection
        For Each drawingView As DrawingView In m_selectEvents.SelectedEntities
            selectedViews.Add(drawingView)
        Next
        MsgBox(selectedViews.Count)
    End Sub
    Private Sub cmdCancel_Click(sender As Object, e As EventArgs) Handles cmdCancel.Click
        Me.Close()
    End Sub
End Class
I'm able to call the form from the ribbon no problem, but the SelectEvents interaction won't allow the user to select anything in Inventor. It's as if the SelectionFilter isn't letting anything through at all. I'm not getting any error at compilation or runtime, but I'm using VS2017 Community, so I don't have real-time debugging. Can anyone help please?
smilinger
What do you mean you don't have real-time debugging? VS2017 community is more than enough for debugging inventor addin.
You need to set the output and debug option in your project settings and click start debug to let VS start Inventor for debugging. Just set the breakpoints you need then it's OK.
bradeneuropeArthur
Put This in your code:
m_interactionEvents.SelectionActive = True
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
bradeneuropeArthur
I also found this:
http://modthemachine.typepad.com/my_weblog/2012/07/set-embed-interop-types-to-false-to-avoid-problem...
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
tdant
A little more research and I learned about the native debugging capabilities in VS2017. I fired that up and everything executes just fine. I added that line of code (which interestingly enough doesn't show up in the API reference manual), but it didn't change anything. What's really bugging me is that this exact same code in VBA form works beautifully. What could be so different between VBA and VB.NET?
