Update all views in a sheet to turn on Associative check box - iLogic
Is it possible to turn on the Associative check box for all views in a drawing using iLogic?
Here is what I have so far which does the opposite of what I want:
Dim oDrawDoc As DrawingDocument
oDrawDoc = ThisApplication.ActiveDocument
Dim oSheet As Sheet
Dim oDrawView As DrawingView
For Each oSheet In oDrawDoc.Sheets
For Each oDrawView In oSheet.DrawingViews
Representation = oDrawView.ActiveDesignViewRepresentation
If Representation <> "" Then
oDrawView.SetDesignViewRepresentation(Representation, False)
'End If
Next
Next
The problem is that the Representation = "" if the associative box is unchecked. And I require the Representation name to SetDesignViewRepresentation and set the Associative value to True.
This is a related post:
https://forums.autodesk.com/t5/inventor-customization/api-get-the-quot-design-view-representation-qu...
Xun.Zhang
Hi @Anonymous,
As Jon indicated, there is a way to turn on/off the "Associative" box is to use DrawingView.SetActiveDesignViewRepresentation("myDVR", True)
(i.e., it takes an optional second argument that controls the associativity).
In your case, you have query out all related view name first, but not 100% sure.
@JaneFan, any good idea here?
Thanks!
Xun
Hi @Xun.Zhang,
Thanks for your response.
This is exactly my issue, I don't know how to effectively query out all related design view representation names first (if associative tick box is off).
Any ideas?
