vb.net get user defined properties from vault
snappyjazz
snappyjazz
I am writing a program that will put custom properties on files (Inventor Pro 2021). Since the properties exist in Vault (Vault Pro 2021), I am curious if I can access the user defined properties in vault. Some of the UDPs have a list of values; which would be nice to use so I can put the correct value of the new custom properties on the file. The screenshot below shows the list of UDPs and an example of the list of values. Please can you help?
bradeneuropeArthur
I don't know if that is supported via the API from Vault.
I have an addin that reads all property values in Vault in a Inventor Dialog.
I need to take a look at it next week
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
