- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Here is my process situation:
- Drawing file is opened from Vault
- Drawing file is NOT checked out.
- I DO NOT WANT TO CHECK THE FILE OUT
- iLogic is activated by user
- iLogic adds text to the drawing
- User is prompted "FILE.DWG" is not checked out." "Do you want to check it out?" } This is what i need help with.
- SELECT NO } What ilogic code is used to "CLICK THE NO BUTTON"
- iLogic continues to run and print the file
iLogic should click the NO button, not the user.
