Edit all parts of Assembly
I have a script that updates some iproperties and does some fancy things to the parts we create. it works like a charm, but Now we need to run it on old files.
I would need an Ilogic script, that you run on an Assembly, and all it does is iterate all parts, and if it is an IPT then it activates it (like qhen you activate it for editing) waits a second and then deactivates it.
this procedure will automatically run the script on every ipt that we have in that big assembly and would run on its own. I would like a solution like this better than editing the main script.
Can this be done? I know how to go through an assembly recursively, just would need to understand how to edit a file and then stop editing...
thanks
marcin_otręba
do you really need to edit that document ?
if not you can use
Dim ass As AssemblyDocument
Set ass = ThisApplication.ActiveDocument
Dim pdoc As PartDocument
For Each pdoc In ass.AllReferencedDocuments
-----run you ilogic here
------ or use   pdoc.Views.Add to open in new window
Next
if you want to edit then:
Private Sub aa()
Dim oAsmDoc As AssemblyDocument
Set oAsmDoc = ThisApplication.ActiveDocument
    Call TraverseAssembly(oAsmDoc.ComponentDefinition.Occurrences)
End Sub
Private Sub TraverseAssembly1(Occurrences As ComponentOccurrences)
 On Error Resume Next
    Dim oOcc As ComponentOccurrence
    For Each oOcc In Occurrences
        If oOcc.DefinitionDocumentType = kAssemblyDocumentObject Then
            Call TraverseAssembly(oOcc.SubOccurrences)
        If oOcc.Definition.Document.DocumentType = kPartDocumentObject Then
               oOcc.Edit
               oOcc.ExitEdit
Next
End Sub
Hi, maybe you want to check my apps:
DrawingTools   View&ColoringTools   MRUFolders
Thanks, it works, but it crashes on iparts. is there a way to skip iparts?
marcin_otręba
try IsiPartMember if is true then skip
