Trim parameter from Trailing zeros
reggie.mostert
reggie.mostert
I have the same problem as this guy:
https://forums.autodesk.com/t5/inventor-customization/trim-parameter-values-for-trailing-zeros/td-p/...
I have a code to round up parameters with the unit "mm" to be whole numbers. This is important in our assets for the BOM list in the end.  I use the following code:
Dim UserParams As UserParameters
UserParams = ThisApplication.ActiveDocument.ComponentDefinition.Parameters.UserParameters
For Each Item In UserParams
	 	If Item.Units = "mm" Then
			Item.Value = Ceil(Item.Value)
Next
This results in the parameters getting x,00000000 mm behind it. This is very confusing for the end user that uses the assets/parameters. How do i get rid of the zeroes?
bradeneuropeArthur
Dim p As Inventor.PartDocument = ThisApplication.ActiveDocument
UserParams = p.ComponentDefinition.Parameters.UserParameters
Dim item As Inventor.Parameter
'Ceil()
For Each item In UserParams
	 	If item.Units = "mm" Then
			'MsgBox (item.modelvalue)
			item.Value = Ceil(item.Value*10)/10
Next
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
dutt.thakar
@reggie.mostert
If you are using iLogic try the below code and see if this gives you the result you need.
			Dim x As Double = Ceil(Item.Value)
			 Parameter(Item.name) = x*10
Next
RuleParametersOutput
InventorVb.DocumentUpdate()
If this answer has solved your problem please ACCEPT SOLUTION and hit like if you found it helpful..!
Dutt Thakar
LinkedIn
reggie.mostert
Thanks guys! The code from @dutt.thakar worked fine. thanks again!
