Flipping a flat pattern in sheet metal part
Message 1 of 11
When I enter a drawing made from a sheet metal part, inventor always defaults the flat pattern to have all the bends going down.  I actually need the bends coming in as 'up' instead. Is there any way to automate this ?
Replies (10)
Message 2 of 11
bradeneuropeArthur
You know that you can change that in the flat-pattern definition within inventor!?
Or do you need it with coding?
And do you need it in i-logic; VBA; Vb.net; or else?
Regards
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 3 of 11
Yes, I do it manually every time as of now. Trying to automate processes for my company.  Preferably ilogic.  Will try to incorporate this with a code that streamlines most of the process of making drawings.
Message 4 of 11
bradeneuropeArthur
Dim a As Inventor.PartDocument = ThisDoc.Document
'Dim su As Inventor.DocumentTypeEnum = a.DocumentSubType
If a.SubType = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then
	Dim s As Inventor.SheetMetalComponentDefinition = a.ComponentDefinition
	Dim f As Inventor.FlatPattern = s.FlatPattern
	'f.FlatPatternOrientations.ActiveFlatPatternOrientation.FlipAlignmentAxis
	Dim fl As Inventor.FlatPatternOrientation = f.FlatPatternOrientations.Item(1)
	fl.FlipBaseFace= True
	'MsgBox ("")
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 5 of 11
bradeneuropeArthur
Or use this to flip it back an forward:
	If fl.FlipBaseFace = False Then
		fl.FlipBaseFace = True
		ElseIf fl.FlipBaseFace = True
			fl.FlipBaseFace= False
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 6 of 11
Looks great, would you happen to know if this rule can be run from a drawing ?  It is usually in the drawing where my coworkers notice that the part needs to be flipped. (The majority of the bends need to be up instead of down).
Message 7 of 11
bradeneuropeArthur
sure it can hang on..
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 8 of 11
bradeneuropeArthur
Dim dwg As Inventor.DrawingDocument = ThisDrawing.Document
Dim v As Inventor.DrawingView = dwg.ActiveSheet.DrawingViews.Item(1)
'v.ReferencedDocumentDescriptor.ReferencedDocument
Dim a As Inventor.PartDocument = v.ReferencedDocumentDescriptor.ReferencedDocument 'ThisDoc.Document
dwg.Update
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 9 of 11
bradeneuropeArthur
More user friendly with a Picker selection from the user:
Dim v As Inventor.DrawingView '= dwg.ActiveSheet.DrawingViews.Item(1)
v = ThisApplication.CommandManager.Pick(Inventor.selectionfilterenum.kDrawingViewFilter,"Select a Flat Pattern View")
dwg.Update
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 10 of 11
bradeneuropeArthur
Next the error will occur when the View is no Flat Pattern view:
Now you receive a message if it is not:
v = ThisApplication.CommandManager.Pick(Inventor.selectionfilterenum.kDrawingViewFilter, "Select a Flat Pattern View")
If v.IsFlatPatternView = True Then
dwg.Update
Else
	MsgBox("This View Contains no Flat Pattern")
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 11 of 11
Thanks, code will be used !
