Triggers and VBA
Triggers and VBA
idealogicERZYZ
Triggers and VBA
idealogicERZYZ
I have the rule "r1" and need to run it when opening any file.
How to do it best?
greetings
bradeneuropeArthur
use auto macros:
like AutoOpen Macro...
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
idealogicERZYZ
I need my rule "r1" to run:
- when opening the assembly file
- when changing iProperies
greetings
bradeneuropeArthur
Then you better start programming your own add ins in vb.net. You need application events for this. At least for the on iproperty change event. Please let me know if you are interested in this...
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
