Derived Part - Replace Model Reference - iLogic => VB.Net
GeorgK
Advisor Advisor
GeorgK
Hello together,
I tried to convert the iLogic-program to VB.Net.
https://forums.autodesk.com/autodesk/attachments/autodesk/78/469742/1/BasePartReplacer.iLogicVb.txt
Is there a simple method to convert the
Dim selectedName As String = InputListBox("Select the part to replace", partNameList, partNameList(0), "Replace Part", "Parts").ToString()
to VB.Net?
Thank you
Georg
bradeneuropeArthur
Dim selectedName As String = InputBox("Select the part to replace", "partNameList", "partNameList(0)", , )
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
GeorgK
Thank you very much. That's quite easy. Sometimes you do not see the forest for the trees
ngdnam88
Hi @GeorgK,
Is possible to share your VB.NET code? I'm trying converting to VB.NET too but got an error:
Help me please,
A.Acheson
Hi @ngdnam88
I would think your error is unrelated. Can you share the full code and the error message your receiving? It might be best also to start a new post as this one is already solved.
Regards
Alan
