Start .ipt environment with a sketch on the XY (or any given) plane
Please forgive me if this is a simple or rudimentary task, because I thought the standard Inventor .ipt template did this but if so, someone has buggered it up here where I work.
Here is what we want: When you click on the standard .ipt template, we want the .ipt environment to open directly into a sketch on the XY (or any given) plane. Is there a simple way to achieve this, or does it need to be done via iLogic or VBA?
Thank you in advance.
bradeneuropeArthur
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
