Create section views from work plane
I am currently trying to automate the creation of section views using a work plane as my sketch. I know how to make the section view and place it, however I am having difficulty projecting the work plane and creating the sketch line. Thanks in advance.
dgreatice
hi,
Before you go to automate, did you try to "Projection Geometry that Work Plane when create sketch for Section View manually?
I think we cant, so I think you cant automate this process.
Please use the ACCEPT AS SOLUTION or KUDOS button if my Idea helped you to solve the problem.
Autodesk Inventor Professional Certified 2014
I've already automated my drawing. The only thing I'm missing is being able to make the work plane show up in a drawing sketch so I can make a section view from it.
dgreatice
Can you give example with video how to create section view using projection line from Work plane "manually"?
This process will be:
1. Include Work plane,
2. Create Sketch in selected view,
3. Projection Geometry work plane,
4. Create line base on start/end point of Projection line,
5. Create section view using line.
I cant select projection line for create section view, then I provide step 4.
