Copy custom iProperty from Child to parent
RoyWickrama_RWEI
Advisor Advisor
RoyWickrama_RWEI
In my modelling, I come across with situations where I have to create an assembly for a part or an assembly (only one of them exists in this new assembly)  itself.
However, now I need to import the iProperties from the child part (or assembly) to this new assembly.
I havbe a rule, but not doing well: it creates additional custom iProperties
I request help.
Attached sample file.
Inventor 2015/2018
Thanks.
RoyWickrama_RWEI
Basically, I need to get copied Part Number, Description and Total Qty custom iProperty.
My code below does not work. Request help!
Note: This assembly has only one child (either one part or one assembly) always.
Sub Main()
oRuleNo = "iL0050"
Dim openAssy As Document
oRun_or_Not = MessageBox.Show("DO YOU WANT TO RUN THIS RULE?", oRuleNo, MessageBoxButtons.YesNo)
If oRun_or_Not = vbNo Then Exit Sub
openAssy = ThisDoc.Document
Dim oPropertySet_openAssy As PropertySet
Dim oChildDoc As Document
oPropertySet_openAssy = openAssy.PropertySets.Item("Inventor User Defined Properties")
If openAssy.DocumentType = kAssemblyDocumentObject Then
	oChildDoc = openAssy.AllReferencedDocuments.item(1)
	MessageBox.Show("oChildDoc: " & oChildDoc.FullFileName, "Title")
	iProperties.Value("Project", "Part Number") = iProperties.Value(oChildDoc, "Project", "Part Number")
	iProperties.Value("Project", "Description") = iProperties.Value(oChildDoc, "Project", "Description")
	iProperties.Value("Custom", "TOTAL QTY") = iProperties.Value(oChildDoc, "Custom", "TOTAL QUANTITY")
Else
	MessageBox.Show("This document is not an assembly!", "INFORMATION")
End Sub
chandra.shekar.g
Autodesk Support
Autodesk Support
@RoyWickrama_RWEI,
Try below iLogic code to update iProperties from child document to main assembly. Before running this code, make sure that custom iProperties are defined with same name. Otherwise, code throws exception.
Sub Main()
oRuleNo = "iL0050"
	oChildDoc = openAssy.AllReferencedDocuments.Item(1)
	iProperties.Value("Project", "Part Number") = oChildDoc.PropertySets.Item("Design Tracking Properties").Item("Part Number").Value
	iProperties.Value("Project", "Description") = oChildDoc.PropertySets.Item("Design Tracking Properties").Item("Description").Value
	iProperties.Value("Custom", "TOTAL QTY") = oChildDoc.PropertySets.Item("User Defined Properties").Item("TOTAL QTY").Value
Else
oSave()
End Sub
Sub oSave()
ThisDoc.Save
End Sub
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
RoyWickrama_RWEI
The code worked perfectly.
I thought I will be doing with an assembly of either one part or or assembly. But, I got to do with a weldment where I inserted a part (this is a sketch anyway).
To do with any assembly, I think, I need to select the oChildDoc from a list; for example,
Dim oChildren_Assy As New ArrayList
For Each oChildDoc In openAssy.AllReferencedDocuments
	oChildren_Array.add(oChildDoc.FullFileName)
Next oChildDoc
oChildDoc = InputListBox("Prompt", oChildren_Assy, oChildren_Assy(0), Title := "Title", ListName := "List")
Could you provide some solution. Sorry to disturb you.
the assembly is going to have a
chandra.shekar.g
Autodesk Support
Autodesk Support
@RoyWickrama_RWEI,
Try below iLogic code to select child document from assembly.
Dim openAssy As AssemblyDocument
openAssy = ThisApplication.ActiveDocument
	oChildren_Assy.Add(oChildDoc.FullFileName)
Next oChildDoc
childName = InputListBox("Prompt", oChildren_Assy, oChildren_Assy(0), Title := "Title", ListName := "List")
Dim selectedDoc As Document
	If oChildDoc.FullFileName = childName Then
		selectedDoc = oChildDoc
		Exit For
Next oChildDoc
MessageBox.Show(selectedDoc.DisplayName, "Title")
Please feel free to contact if there is any queries.
If solves problem, click on "Accept as solution" / give a "Like".
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
RoyWickrama_RWEI
Thanks a lot again. The help was almost perfect.
The little issue was, I could not read the file name in the message box because full file name is too long. Therefore, I revised the code as shown below (mostly it is your code: Thanks):
I would like to ask, is it possible to increase the width of the message box?
Dim oChildren_in_Assy As New ArrayList
Dim FName_Children As New ArrayList	'FN: File Name
		oChildren_in_Assy.Add(oChildDoc.FullFileName)
		FName_Pos = InStrRev(oChildDoc.FullFileName, "\", -1)
		FName_Child = Right(oChildDoc.FullFileName, Len(oChildDoc.FullFileName) - FName_Pos)
		FName_Children.Add(FName_Child)
	Next oChildDoc
	Child_Selected = InputListBox("SELECT SOURCE DOCUMENT", FName_Children, FName_Children(0), Title := "TO COPY PROPERTIES FROM", ListName := "REFERENCE DOCUMENTS")
'	oIndex = FName_Children.IndexOf(Child_Selected)
Else
RoyWickrama_RWEI
Hi Chandra Shekar Gopal;
Starting from your help (thanks a lot), I further developed the code to:
  • copy all custom properties from the selected child
  • copy only pre-defined (in the rule) properties
