Tot Volume Tot weight
bespel
bespel
hope you can help me.
Is it possibile with a rule, in an assembly,  to write as parameters or custom iprop(at assembly level)  the total weight and total volume summed for every parts?
Ex. in an assembly I have 10 parts called "PartA", 1 kg and 1 dm^3 each.
The rule should write(in the assembly)  (as parameters or custom iprop)
Tot_Vol 10
Tot_Weight 10
I really hope that it's possible...
Thanks!
bradeneuropeArthur
For my understanding:
Assembly X
>>Part A - 1 kg each- 10 times = total weight = 10 kg
>>Part B - 2 kg each- 20 times = total weight = 40 kg
What should the property be called in the Assembly X for each part?
"Part A total Weight" with value 10 kg
"Part B total Weight" with value 40 kg
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Sergio.D.Suárez
Hi, Try this rule from the assembly.
This rule will look at the BOM parts only, take the quantity and multiply it by the volume and with this value it will create a property called "TotalVolume" in each part. It will also create another custom property called "TotalMass".
I hope this is what you are looking for or that at least it will help you to achieve it. regards
Dim doc As AssemblyDocument = ThisDoc.Document
Dim oAssyDef As AssemblyComponentDefinition = doc.ComponentDefinition
Dim oBOM As BOM = oAssyDef.BOM
oBOM.PartsOnlyViewEnabled = True
Dim oBOMView As BOMView = oBOM.BOMViews.Item(3)'BOM parts only
Dim oBOMRow As BOMRow
For Each oBOMRow In oBOMView.BOMRows
	Dim Qty As Double = oBOMRow.TotalQuantity
	Dim rDoc As Document = oBOMRow.ComponentDefinitions.Item(1).Document
	Dim oVoltotal As Double = rDoc.ComponentDefinition.MassProperties.Volume * Qty
	Dim oMassTotal As Double = rDoc.ComponentDefinition.MassProperties.Mass * Qty
	Try
	rDoc.PropertySets.Item("Inventor User Defined Properties").Item("TotalVolume").Value = Round(oVoltotal, 0) & " cm^3"
	Catch
	rDoc.PropertySets.Item("Inventor User Defined Properties").Add(Round(oVoltotal,0) & " cm^3", "TotalVolume")
	End Try
	Try
	rDoc.PropertySets.Item("Inventor User Defined Properties").Item("TotalMass").Value = Round(oMassTotal,3) & " Kg"
	Catch
	rDoc.PropertySets.Item("Inventor User Defined Properties").Add(Round(oMassTotal,3) & " Kg", "TotalMass")
	End Try
Next
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
bespel
You are very kind my friend.
I will test these.
Thanks!
