iLogic Drawing sheet color
Raf_
Raf_
Hi All,
Is it possible to change drawing sheet color using iLogic external rule, also to add tick to Preserve Orphaned  Annotations and change dimensions text alignment as per screenshots below:
bradeneuropeArthur
For VBA:
Public Sub main()
Dim a As Application
Set a = ThisApplication
Dim b As DrawingDocument
Set b = a.ActiveDocument
Dim c As DrawingOptions
Set c = a.DrawingOptions
Dim oColor As Color
Set oColor = a.TransientObjects.CreateColor(255, 255, 255)
b.SheetSettings.SheetColor = oColor
b.DrawingSettings.PreserveOrphanedAnnotations = True
b.DrawingSettings.DimensionTextAlignment = kMaintainCenteredTextAlignment
End Sub
For I-logic:
Public Sub main()
a = ThisApplication
Dim oColor As Color
End Sub
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Raf_
Thank you very much works perfectly, just remove 'Set' from ilogic code 🙂
