Toggle visibility 3rd party object in .dwg
Hi all,
I was wondering if there is a way to toggle the visibility of a 3rd party object within a .dwg with a rule or something?
MechMachineMan
Here is one I wrote than will start from an assembly and iterate down.
Sub Main()
	Dim oDoc As Document = ThisApplication.ActiveDocument
	For Each oOLEFileRef In oDoc.ReferencedOLEFileDescriptors
	        oOLEFileRef.BrowserVisible = True
	Next
	For Each oSubDoc As Document In oDoc.AllReferencedDocuments
		If oSubDoc.ReferencedOLEFileDescriptors.Count > 0
			 For Each oOLEFileRef In oVisiDoc.ReferencedOLEFileDescriptors
Next End If Next MsgBox("Rule Complete!",,"iLogic") End Sub
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
