I can create " centermarks " from iLogic ?
Hello everyone!
I 'm trying to create center marks using iLogic .
I created attributes "attribute helpper " Brian Ekins
http://modthemachine.typepad.com/my_weblog/2013/08/attribute-helper-update.html
And then I try to use my element that attribute as input and generate the center mark .
Here my code:
Dim oDrawDoc As DrawingDocument
oDrawDoc = ThisDoc.Document
Dim oSheet As Sheet
oSheet = oDrawDoc.ActiveSheet
Dim oView As DrawingView
oView = ActiveSheet.View("FRONT_VIEW").View
Dim oAssyDoc As AssemblyDocument
oAssyDoc = ActiveSheet.View("FRONT_VIEW").ModelDocument
Dim oCenterMarks As CenterMarks
oCenterMarks = oSheet.CenterMarks
Dim aoEdge4 As Face
oObjs = oAssyDoc.AttributeManager.FindObjects("DIM", "FDE", "1")
aoEdge4 = oObjs.item(1)
Dim aoDrawCurves4 As DrawingCurve
oDrawViewCurves = oView.DrawingCurves(aoEdge4)
aoDrawCurves4 = oDrawViewCurves.item(1)
Dim oDim2 As CenterMarks
oDim2 = oCenterMarks.Add(oSheet.oSheet.CreateGeometryIntent(aoDrawCurves4))
And i have this error:
This is the reason why I wonder if you can use center marks in iLogic .
I am new to programming , to generate this code and used my logic to replace that eh caught fragments found in this forum but since it can not do.
an apology for my bad English and dialog with the error displayed in Spanish .
Thank you very much! Greetings to all
bshbsh
Have a look at your last code line (oDim2) which has two oSheet. I guess that's what the error message says as well.
Thanks bshbsh
Eliminate double " oSheet " and the center mark is created but now I get this error.
In others attempts i have already receibed the error but y do not quite understad that refers to.
Any suggestions, i´m missing something?
Thanks again.
After calmly review my code I realized that possibly had a letter " s " of more syntax in my code.
Delete it and no longer under more mistakes , all you notice is that the command remains active waiting terminated by right and click Cancel .
But I can run my following iLogic rules without any problem .
So they were my codes to create a line of Bisector center and center mark .
Dim oSheet As Sheet
Dim oCenterLines As Centerlines
oCenterLines = oSheet.Centerlines
Dim aoEdge4 As Face
oObjs = oAssyDoc.AttributeManager.FindObjects("DIM", "FCL", "1")
Dim aoEdge3 As Face
oObjs = oAssyDoc.AttributeManager.FindObjects("DIM", "FCR", "1")
aoEdge3 = oObjs.item(1)
Dim aoDrawCurve3 As DrawingCurve
oDrawViewCurves = oView.DrawingCurves(aoEdge3)
aoDrawCurves3 = oDrawviewCurves.item(1)
Dim oDim2 As CenterLine
oDim2 = oCenterLines.AddBisector(oSheet.CreateGeometryIntent(aoDrawCurves3), oSheet.CreateGeometryIntent(aoDrawCurves4))
Dim oSheet As Sheet
oView = ActiveSheet.View("LEFT_VIEW").View
oAssyDoc = ActiveSheet.View("LEFT_VIEW").ModelDocument
Dim aoEdge4 As Face
oDim2 = oCenterMarks.Add(oSheet.CreateGeometryIntent(aoDrawCurves4))
i use to eliminate the following rules
Dim oDoc As DrawingDocument
oDoc = ThisDoc.Document
Dim oSheet As Sheet
Dim oCL As Centerline
For Each oSheet In oDoc.Sheets
    oSheet.Activate
    For Each oCL In oSheet.Centerlines
        'If oCL.Attached = False
            oCL.Delete
        'End if 'Centerline attached
    Next 'Centerline
Next
Dim oDoc As Document
oDoc = ThisServer.ActiveDocument
Dim oSheet As Sheet
Dim oCM As CenterMark
    oSheet.Activate
    For Each oCM In oSheet.Centermarks
            oCM.Delete
    Next 'Centerline
Next
Now i'm trying to create a center line but i find that my imput objects were incorrect and that the help says something about a collection of objects. in the method that had been using the center marks or lines they were generated through GeometryIntent.
Someone could guide me a bit about how ObjectCollection used please?
Regards
