To make the component flexible in assembly
Is there a API for making the component in assembly flexible. Here in my case in the nut and bolt assembly to lead support i want to make the nut flexible. How can i achieve this , i need information which API i need to use.
Hi, this should do the trick:
Dim doc As AssemblyDocument = ThisDoc.Document
Dim oAsmCompDef As AssemblyComponentDefinition = doc.ComponentDefinition
Dim oOcc1 As ComponentOccurrence = oAsmCompDef.Occurrences.ItemByName("nut") 'replace "nut" with your part number
oOcc1.Flexible = True
Thank you!!
I am trying to model a flexible bow limb infusion 360 and need some advice on how to accomplish this.
MechMachineMan
Adaptivity, if that exists in fusion, is probably the only way to accomplish it.
This is the Inventor Forums though, not the Fusion forums, which is likely the better place to be asking.
https://forums.autodesk.com/t5/fusion-360/ct-p/1234
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
