Stuck in iLogic with IsiAssemblyMember
Rob67ert
Rob67ert
I need some help form you 🙂
I have some iLogic that helps te determine what sort of file I have, I will use it do let it run some other iLogic.
The whole routine runs good, but it gives an error when I save an iAssembly member.
Hope someone can help me get the error out and make a good working routine.
The error:
Error in rule: 00_Start, in document: ilogic Test iAssembly File-01.iam
Kan lid niet vinden. (Exception from HRESULT: 0x80020003 (DISP_E_MEMBERNOTFOUND))
More Info:
System.Runtime.InteropServices.COMException (0x80020003): Kan lid niet vinden. (Exception from HRESULT: 0x80020003 (DISP_E_MEMBERNOTFOUND))
at Microsoft.VisualBasic.CompilerServices.LateBinding.LateGet(Object o, Type objType, String name, Object[] args, String[] paramnames, Boolean[] CopyBack)
at Microsoft.VisualBasic.CompilerServices.NewLateBinding.LateGet(Object Instance, Type Type, String MemberName, Object[] Arguments, String[] ArgumentNames, Type[] TypeArguments, Boolean[] CopyBack)
at LmiRuleScript.Main()
at Autodesk.iLogic.Exec.AppDomExec.ExecRuleInAssembly(Assembly assem)
at iLogic.RuleEvalContainer.ExecRuleEval(String execRule)
Here the part of the routine that gives an error:
SyntaxEditor Code Snippet
Dim oDoc As Document = ThisDoc.Document
'Assembly file
If oDoc.DocumentType = Inventor.DocumentTypeEnum.kAssemblyDocumentObject Then
    If oDoc.ComponentDefinition.IsiAssemblyFactory Then
        MessageBox.Show("This is an iAssemblyFactory", "I will stop")
        Return
    Else If oDoc.ComponentDefinition.IsiAssemblyMember Then
        MessageBox.Show("This is an iAssemblyMember", "I will stop")            'Here it gives an error when I save the iAssembly Members
        Return
MessageBox.Show("This is an Assembly", "I will Return")
The whole code:
'Presentation file
If oDoc.DocumentType = Inventor.DocumentTypeEnum.kPresentationDocumentObject Then
    MessageBox.Show("This is a Presentation", "I will stop")
    Return
'Part file
Else If oDoc.DocumentType = Inventor.DocumentTypeEnum.kPartDocumentObject And oDoc.SubType <> "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then
    If oDoc.ComponentDefinition.IsiPartFactory Then
        MessageBox.Show("This is an iPartFactory", "I will stop")
        Return
    Else If oDoc.ComponentDefinition.IsiPartMember Then
        MessageBox.Show("This is an iPartMember", "I will stop")
        Return
    If TypeOf ThisApplication.ActiveEditObject Is Sketch Then
        MessageBox.Show("You have a sketch active in a part file.", "Stop the Sketch")
    Else
        MessageBox.Show("This is a Part", "I will Return")
'SheetMetal file
Else If oDoc.DocumentType = Inventor.DocumentTypeEnum.kPartDocumentObject And oDoc.SubType = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then
    Else
        MessageBox.Show("This is a Sheetmetal Part", "I will Return")
'Assembly file
Else If oDoc.DocumentType = Inventor.DocumentTypeEnum.kAssemblyDocumentObject Then
        Return
        Return
        MessageBox.Show("You have a sketch active in an assembly file.", "Stop the Sketch")
    Else
'Drawing file
Else If oDoc.DocumentType = Inventor.DocumentTypeEnum.kDrawingDocumentObject Then
        MessageBox.Show("You have a sketch active in a drawing file.", "Stop the Sketch")
    Else
        MessageBox.Show("This is a Drawing", "I will Return")
MessageBox.Show("How did I get here?", "???")
MessageBox.Show("I have Returend", "Yeah")
Robert
If you find this reply helpful ? It would be nice if you use the Accept as Solution or Kudos button below.
Rob67ert
Anyone have any ideas?
Robert
t_hascj
Hi Robert,
I was not able to reproduced your issue on my dataset. Could you provide a dataset?
Jaroslav
Rob67ert
Here the test files.
What is have noticed is that is sometimes happen with the iPart and the other time with the iAssembly.
After you restart Inventor is will work for some time.
My test methode:
save the file and for the iPart en iAssembly, first a Rebuild all and then Generate files.
Error message:
Error in rule: What File is it, in document: ilogic Test iAssembly File.iam
Robert
t_hascj
Hi Robert,
Could you try to update your code:
Before:
        Return
        Return
After:
    Dim oAssyDoc As Inventor.AssemblyDocument = oDoc
    If oAssyDoc.ComponentDefinition.IsiAssemblyFactory Then
        Return
    Else If oAssyDoc.ComponentDefinition.IsiAssemblyMember Then
        Return
Jaroslav
Rob67ert
Thank you Jaroslav,
To make it bulletproof I changed this to:
    Dim oPartDoc As Inventor.PartDocument = oDoc
    If oPartDoc.ComponentDefinition.IsiPartFactory Then
        'MessageBox.Show("This is an iPartFactory", "I will stop")
        Return
    Else If oPartDoc.ComponentDefinition.IsiPartMember Then
        'MessageBox.Show("This is an iPartMember", "I will stop")
        Return
 It works great now.
Thanks.
Robert
