Thumbnail form custom Content Center library. Can you get the normalt thumbnail ?
Darkforce_the_ilogic_guy
Advisor Advisor
I would like to see the current file and not an standard thumbnail form content center
like this
not like this
is this possible ?
bradeneuropeArthur
Is this what you need?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
No.  I need to be ably to see the finished part. We are using Content center to create custom part with a lot of properties on.  so we start out selecter a round bars Ø35 x lenght  by using the Counter Center as custom
then we might add some more feature after that.. Today All Round bart thoumbnail looks like this
no matter what we have done with it.. I want to see the real part that might look like this
or
 or
Michael.Navara
This is a document setting. Change it in iProperties window -> Save
Looks like that work.  is that a change i need to make on the templete file  or  a setting in inventor .. If I want all files like that ?
thanks for the help so fare 😀
Michael.Navara
In my opinion it is not possible to change this setting in template, because each family in ContentCentrer has it's own template
But you can switch it by simple iLogic script (before save, after new, etc.).
Dim doc As Document = ThisDoc.Document
doc.SetThumbnailSaveOption(ThumbnailSaveOptionEnum.kActiveComponentIsoViewOnSave)
emanuel.c
If it's useful to anyone, I run this from Part or Assembly level to modify ALL parts to ISO view of Thumbnail. Enjoy.
Public Sub Main()
	If ThisApplication.ActiveDocumentType = DocumentTypeEnum.kPartDocumentObject Then
		Dim oDoc As PartDocument = ThisApplication.ActiveDocument
		Try
			'set iproperty to use ISO view on save
			oDoc.SetThumbnailSaveOption _
			'save the file
			oDoc.Save
		Catch
		End Try
	ElseIf ThisApplication.ActiveDocumentType = DocumentTypeEnum.kAssemblyDocumentObject
		Dim oDoc As AssemblyDocument = ThisApplication.ActiveDocument
		Dim oFileInfo As String = oDoc.FullFileName
		Dim result = MessageBox.Show("You're running multiple parts in this Assembly " & vbCr & fileName & vbCr & "Do you want to continue??", "Run GS and Other Rules", MessageBoxButtons.OKCancel, MessageBoxIcon.Question, MessageBoxDefaultButton.Button1)
		If result = vbOK Then
			RunExternalRules
		Else
			Return
		End If
		Dim oProgressBar As Inventor.ProgressBar
		oProgressBar = ThisApplication.CreateProgressBar(False, PartCount, oMessage, True)
	End If
End Sub
Sub RunExternalRules
	oDoc = ThisApplication.ActiveDocument
	Dim iDoc As Document
	'Set counter for counting parts
	Dim iPartCount As Integer
	iPartCount = 0
	'Progress bar
	oMessage = "Editing All Parts And Saving, Please Wait..."
	PartCount = oDoc.AllReferencedDocuments.Count
	Dim assembly As Inventor.AssemblyDocument = ThisDoc.Document
	'Iterate through all of the occurrences in the assembly
	For Each iDoc In oDoc.AllReferencedDocuments
		iPartCount = iPartCount + 1
		Dim fileName As String  = IO.Path.GetFileNameWithoutExtension(iDoc.FullFileName)
		'Update the progress bar
		'If UserWantsToCancel Then Return
		oProgressBar.Message = ("Working on part " & iPartCount & " of " & PartCount & " | " & fileName)
		oProgressBar.UpdateProgress
		Try
			ThisApplication.Documents.Open(iDoc.FullFileName)
			IDoc.SetThumbnailSaveOption _
			'save the file
			iDoc.Save
			iDoc.Close
		Catch
			iDoc.Close
		End Try
	Next
	oProgressBar.Close
End Sub
Private Function UserWantsToCancel(oprogressBar As Inventor.ProgressBar)
	If (UserClickedOnCancel) Then
		MsgBox("User clicked cancel and it has been detected now.")
		' Add code here for clean exit of the rule.
		' If you work with transactions then this could be
		' the place To role back any changes
		oprogressBar.Close()
		Return True
	End If
	Return False
End Function
