Find frame generator assembly from frame gen part
Rich-T
Rich-T
Hi.
I'm trying to write an iLogic rule to find a frame generator assembly from one if its sub parts.
The user selects a part in the assembly and if it is flagged as a frame generator part by an iproperty value then I want to get the part number/filename of the frame generator assembly.
Is this possible? See existing code below
Sub main()
	Dim oPart As ComponentOccurrence
	Dim Prop As String
	Dim oDoc As Document
	oPart = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kAssemblyLeafOccurrenceFilter, "Select component")
	If oPart Is Nothing Then
		Exit Sub
	Else
		oDoc = oPart.Definition.Document
		'MessageBox.Show(oDoc.DisplayName, "Document Name")
		'MessageBox.Show(oDoc.FullFileName, "FullFileName")
	If TypeOf oOccurrence Is ComponentOccurrenceProxy Then
    		Prop = iProperties.Value(oDoc.NativeObject.Name, "Summary", "Title")
		Else
    		Prop = iProperties.Value(oDoc.DisplayName, "Summary", "Title")
	If Prop = "Frame Generator" Then
		'MessageBox.Show(Prop, "iProperty Value")
	'***   FIND THE FRAME GENERATOR ASSEMBLY PART NUMBER HERE ***
End Sub
A.Acheson
Have a read of this post. It uses the has interest so you can specifically target the frame generator addin components.
Regards
Alan
JhoelForshav
Hi @Rich-T
Here's an iLogic example of one way to tackle this problem. It checks if the selected occurrence is a frame member, then looks at its occurrencepath to find the frame document in there 🙂
Dim oOcc As ComponentOccurrence = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kAssemblyLeafOccurrenceFilter, "Select component")
If oOcc IsNot Nothing Then
	Dim oDoc As Document = oOcc.Definition.Document
	If oDoc.DocumentInterests.HasInterest("FrameMemberDoc") Then
		Dim FrameAsm As ComponentOccurrence = oOcc.OccurrencePath.Cast(Of ComponentOccurrence).FirstOrDefault(Function(x As ComponentOccurrence) _
		x.Definition.Document.DocumentInterests.HasInterest("FrameDoc"))
		If FrameAsm IsNot Nothing Then
			Dim FrameAsmDoc As AssemblyDocument = FrameAsm.Definition.Document
			MsgBox("Frame assembly part number: " &
			FrameAsmDoc.PropertySets("Design Tracking Properties")("Part Number").Value _
			& vbCrLf & "Frame assembly displayname: " & FrameAsmDoc.DisplayName)
	Else
		MsgBox("that's not a frame member")
Rich-T
That's excellent, thanks Jhoel
Rich-T
Can you look up one more level - to the assembly containing the "FrameDoc" and return the assembly fullpath and filename ?
JhoelForshav
Hi @Rich-T
Something like this? 🙂
		Dim FrameDocParent As AssemblyDocument
		For i = oOcc.OccurrencePath.Count - 1 To 1 Step -1
			If oOcc.OccurrencePath(i).Definition.Document.DocumentInterests.HasInterest("FrameDoc")
				FrameDocParent = If (i = 1, ThisDoc.Document, oOcc.OccurrencePath(i - 1).Definition.Document)
				Exit For
		Next
		MsgBox("FrameDoc Parent Assembly: " & FrameDocParent.FullFileName)
	Else
Rich-T
VERY NICE.
THANKS JHOEL
