Need Help about AddMateConstrain
Octave.Lab
Message 1 of 8
Octave.Lab
I need your help about how to add mate constrain by using API.
I'd like to connect a conduit (left) and UNV (right)
My Code is below,
Sub AddMateTest01()
    ' Add Mate constrain sammple
    ' Cylindrical Face of Conduit and  Work Axis od Clamp
    Dim oDoc As Inventor.AssemblyDocument
    Set oDoc = ThisApplication.ActiveDocument
    'select couduit
    Dim oConduitFace As Inventor.FaceProxy
    Set oConduitFace = ThisApplication.CommandManager.Pick(kPartFaceCylindricalFilter, "select couduit")
    Dim oUNV_Comp As Inventor.ComponentOccurrence
    Set oUNV_Comp = ThisApplication.CommandManager.Pick(kAssemblyOccurrenceFilter, "select UNIV")
    'select UNV
    Dim oWx As Inventor.WorkAxis
    Set oWx = oUNV_Comp.Definition.WorkAxes.Item("Wx_Unv")
    'Create Proxy
    Dim oWxProxy As Inventor.WorkAxisProxy
    Call oUNV_Comp.CreateGeometryProxy(oWx, oWxProxy)
    'Add Mate
    Dim oMate As Inventor.MateConstraint
    Set oMate = oDoc.ComponentDefinition.Constraints.AddMateConstraint(oConduitFace, oWxProxy, 0)
End Sub
Sub AddMateTest02()
    'select couduit
    'Get Wx of Conduit
    Dim oWxConduit As Inventor.WorkAxis
    Set oWxConduit = oConduitFace.ContainingOccurrence.Definition.WorkAxes.Item(3)
    Dim oWxConduitProxy As Inventor.WorkAxisProxy
    oConduitFace.ContainingOccurrence.CreateGeometryProxy oWxConduit, oWxConduitProxy
    'select UNV
    'Create Proxy
    oUNV_Comp.CreateGeometryProxy oWx, oWxProxy
    'Add Mate
    Set oMate = oDoc.ComponentDefinition.Constraints.AddMateConstraint(oWxConduitProxy, oWxProxy, 0)
End Sub
1st program AddMateTest01 will stop by Error at line 27.
2nd progra will OK.
The difference is whether using   Face proxy  or work axis proxy for constraint.
But I want use Face proxy for mate constrain.
Can you tell me how I can add constrain  correctly?
I attached the Sample project and movie.
-YO
Octave.Lab
https://note.com/yo420186
Replies (7)
Message 2 of 8
A.Acheson
This seems to work for me.
Sub AddMateTest01()
    'select couduit
    'select oUNV
    Dim oUNV_Face As Inventor.FaceProxy
    Set oUNV_Face = ThisApplication.CommandManager.Pick(kPartFaceCylindricalFilter, "select UNIV")
    'Add Mate
    Set oMate = oDoc.ComponentDefinition.Constraints.AddMateConstraint2(oUNV_Face, oConduitFace, 0, InferredTypeEnum.kInferredLine, InferredTypeEnum.kInferredLine, MateConstraintSolutionTypeEnum.kOpposedSolutionType)
End Sub
Regards
Alan
Message 3 of 8
Octave.Lab
@A.Acheson -san
Thank you for your help.
But, I want to add mate with the work axis within the selected occurrence.
Is Face proxy and Work Axis proxy bad match?
-YO
Octave.Lab
Message 4 of 8
A.Acheson
Ok i see. Once you have the occurrence go to definition then axes. To clarify you want to mate axis to axis?
Regards
Alan
Message 5 of 8
Octave.Lab
@A.Acheson
I want to mate Face to Axis.
-YO
Octave.Lab
Message 6 of 8
A.Acheson
This works
Sub AddMateTest02()
    'select couduit
    Dim oConduitFaceProxy As Inventor.FaceProxy
    Set oConduitFaceProxy = ThisApplication.CommandManager.Pick(kPartFaceCylindricalFilter, "select couduit")
   'select UNV Axis
    'Create Proxy as axis is in an assembly
    'Add Mate
    Set oMate = oDoc.ComponentDefinition.Constraints.AddMateConstraint2(oWxProxy, oConduitFaceProxy, 0, InferredTypeEnum.kInferredLine, InferredTypeEnum.kInferredLine, MateConstraintSolutionTypeEnum.kOpposedSolutionType)
End Sub
Regards
Alan
Message 7 of 8
Octave.Lab
It Works!
I understand that i should use AddMateConstraint2 method instead.
Thank you so much for your help.
-YO
Octave.Lab
Message 8 of 8
A.Acheson
I think this will work with either Mateconstraint or Mateconstraint2. I must have left that in there accidently while testing. Try it without.
Regards
Alan
