Structured bill of material returns just the top level assembly
Hi
I'm working on a standalone C# program that uses Inventor Apprentice API. It opens the top level assembly, loops through its BOM rows in Structured View and displays them in a DataGridView.
For a couple of assemblies, the BOMRowsCount (in the below code) is just 1 ( the top-level assembly), whereas if I change the BOMViewType to 'Model Data' or 'Parts Only', it shows up all the BOMRows.
When I open the Structured View tab of Bill of Materials of that assembly in Inventor UI, I can see all the parts & subassemblies listed. But the API fails to retrieve the BOMRows and it doens't throw any exception either.
I don't know what's special/wrong about these assemblies or there is a better way of implementation.
I'm not very familiar with Inventor APIs, any help on better understanding of this behaviour is appreciated.
var assemblyDoc = inventor.Open(assemblyPath);
var components = (Inventor.AssemblyComponentDefinition)assemblyDoc.ComponentDefinition;
Inventor.BOMView structuredView = null;
try
structuredView = components.BOM.BOMViews
.Cast<Inventor.BOMView>()
.Single(view => view.ViewType == Inventor.BOMViewTypeEnum.kStructuredBOMViewType);
var BOMRowsCount = structuredView.BOMRows.Count;
catch (InvalidOperationException x)
// If zero or more than one structured BOM was found.
throw new InventorStructuredBomException(x);
Rekha.
MechMachineMan
You are missing some lines to set the properties of the BOM object.
See documentation here:
http://help.autodesk.com/view/INVNTOR/2018/ENU/?guid=GUID-5E4217C6-FCE6-4006-9232-ACC42372A688
or example in vb.net, but it should get you sorted out:
Sub FetchActiveDocBOM(oXLFileName As String, oExportSheetName As String)
    On Error Resume Next
    Dim oBOM As BOM
    oBOM = invDoc.ComponentDefinition.BOM
    Call oBOM.ImportBOMCustomization("Z:\Python\Engineers folder\Justin\iLogic\BOM_Style.xml")
    oBOM.StructuredViewFirstLevelOnly = False
    oBOM.StructuredViewEnabled = True
 	oBOM.PartsOnlyViewEnabled = True
    Dim oStructuredBOMView
    oStructuredBOMView = oBOM.BOMViews.Item("Structured")
    Call oStructuredBOMView.Sort("Part Number", True)
	Call oStructuredBOMView.Renumber(1,1,)
    Call oStructuredBOMView.Export(oXLFileName, 74498, oExportSheetName)
    If Err.Number <> 0 Then
        MsgBox ("Error Opening/Exporting!: " & Err.Number & " :: " & Err.Description)
    End If
End Sub
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Thanks for your reply Justin.
I'm not able to set these properties, I guess its because I'm using the apprentice API which has limited features (mostly read-only).
But I checked these properties on the assembly, they already have the expected values -
StructuredViewFirstLevelOnly - False
StructuredViewEnabled - True
PartsOnlyViewEnabled - True
Has anyone else encountered this issue before? Any help would be appreciated.
Rekha.
