Run a task that will automatically save as a part multiple times with new names
acanx21
acanx21
I created some parts that are linked to an excel sheet. That excel sheet has a name for the part and all the dimensions and parameters associated with that part name.
As of right now, I am able to save as the part manually with a new name that's on the excel sheet and everything updates.
I want to be able to run something that will save as the part with new names that I can feed it with a list or something so that I don't have to sit there saving as and typing the new name for every single part.
Does anyone have any idea if this would be possible?
CadUser46
Firstly you will need to load the Excel file.  If you search the forum there should be a Brian Erkins post of how to start and stop Excel.
You will need to process the list similar to this
Dim outPath as string: outPath = "\somepath\"
Dim outFullPath as string
Dim i as integer: i=1
Dim fso As New FileSystemObject
'Open the base model
'Save as the new file and iterate down the list of spreadsheet cells
Do while cell.value <> ""
       outFullPath = outPath + workbook.sheets(1).cells(i,1).value
       If fso.FileExists(outFullPath) = False Then oPNDoc.SaveAs outFullPath, True
      i=i+1
next
Inventor 2010 Certified Professional
Currently using 2023 Pro
