derived part - change source?
mslosar
Advisor Advisor
mslosar
Can this be done in ilogic or vb? I have someone here who wants to be able to use the code to be able to switch the source file in a derive part. I know copy design does exactly this in vault. Their department at this time does not have vault and it's unknown if they'll ever get it.
Jesper_S
Hi.
Try this.
Dim oDoc as Document
oDoc = ThisDoc.Document
Dim oRefFile As FileDescriptor
Dim oOrigRefName As Object
For Each oRefFile In oDoc.file.ReferencedFileDescriptors
'get the full file path to the original internal references
oOrigRefName = oRefFile.FullFileName
'present a File Selection dialog
Dim oFileDlg As inventor.FileDialog = Nothing
InventorVb.Application.CreateFileDialog(oFileDlg)
oFileDlg.InitialDirectory = oOrigRefName
oFileDlg.CancelError = True
On Error Resume Next
oFileDlg.ShowOpen()
If Err.Number <> 0 Then
Return
ElseIf oFileDlg.FileName <> "" Then
selectedfile = oFileDlg.FileName
End if
‘replace the reference
oRefFile.ReplaceReference (selectedfile)
InventorVb.DocumentUpdate()
oOrigRefName = “”
Next
iLogicVb.UpdateWhenDone = True
//Jesper
//Jesper
mslosar
I'll give it a try, thanks. 🙂
NorthernCADMonkey
I know this is a old thread, but
I have been using this on previous versions of IV, but we just upgraded to 2023 and now it does not work.
The rule runs, but when I get to point to select a replacement for the derived part everything is blank except for the folders. I can not see any ipt files.
Could this be because of model states?
Does anyone know a fix for this.
Thaanks
IVPro 2025
Vault Pro 2025
