Stock Number as Bin Function
I have a steel rod with special threads on the end which is bought by set lengths then trimmed to fit per job. Is there a way to set this up as a CC part which operates as a custom length but reflects the bought lengths in stock number?
basically a bin function where
0-15in is bought as a 15in
15.1-24 is bought as 24in etc.
bradeneuropeArthur
What increment is required?
1 inch.
For example:
  1. inch = 15 inch
  2. inch = 15 inch
  3. inch = 15 inch
  4. inch = 15 inch
  5. inch = 15 inch
  6. inch = 15 inch
  7. inch = 15 inch
  8. inch = 15 inch
  9. inch = 15 inch
  10. inch = 15 inch
  11. inch = 15 inch
  12. inch = 15 inch
  13. inch = 15 inch
  14. inch = 15 inch
  15. inch = 15 inch
    o
    r also in between them?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
bradeneuropeArthur
Do not understand the answer to my question?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
exact length - Stock length
        1"        =       24"
        2"        =       24"
        24"      =       24"
      24.001" =       36"
        25"      =       36"
        36"      =       36"
      36.001" =       48"
         37"     =       48"
         48"     =       48"
BOM should read stocknumber = "Item-stocklength" QTY = 1 each
But functionally when you pull these out of content center, they should have a custom length property to go into an assembly since they are cut to fit from the stock parts.
