Copy UCS from part to assembly
GeorgK
Advisor Advisor
Message 1 of 13
GeorgK
Hello together,
I have a part with a UCS inside. This part is placed in an assembly. I would like create a new UCS in the assembly with the same orientation as the part UCS.
 Dim oDoc As Document
        oDoc = m_invApp.ActiveDocument
        Dim CompDefs As AssemblyComponentDefinitions
        CompDefs = oDoc.ComponentDefinitions
        Dim oCompDef As AssemblyComponentDefinition
        oCompDef = CompDefs.Item(1)
        Dim oWx As Inventor.WorkAxis
        oWx = m_invApp.CommandManager.Pick(SelectionFilterEnum.kWorkAxisFilter, "Please select WorkAxis:")
        If oWx.IsCoordinateSystemElement Then
            Dim oWxNodeDef As Inventor.NativeBrowserNodeDefinition
            Dim oWxNode As Inventor.BrowserNode
            oWxNodeDef = oDoc.BrowserPanes.GetNativeBrowserNodeDefinition(oWx)
            oWxNode = oDoc.BrowserPanes.ActivePane.TopNode.AllReferencedNodes(oWxNodeDef).Item(1)
            Dim oUCS As Inventor.UserCoordinateSystem
            oUCS = oWxNode.Parent.NativeObject
            Dim oTransMatrix As Matrix
            oTransMatrix = oUCS.Transformation
How could I do this?
Georg
Replies (12)
Message 2 of 13
chandra.shekar.g
Autodesk Support
Autodesk Support
Hi @GeorgK,
In order to copy UCS from part to assembly, UserCoordinateSystemProxy can be created from part and copied into AssemblyDocument.
To illustrate the same,
  1. Launch Inventor 2018
  2. open new assembly document
  3. Download attached part(UCS part.ipt) to desired location
  4. Copy and paste the following VBA code into VBA editor.
  5. Update the path of part in VBA code.
  6. On running the code, a UCS will be copied from part to assembly.
Sub Main()
    Dim oDoc As AssemblyDocument
    Set oDoc = ThisApplication.ActiveDocument
    Dim oDef As AssemblyComponentDefinition
    Set oDef = oDoc.ComponentDefinition
    Dim occMatrix As Matrix
    Set occMatrix = ThisApplication.TransientGeometry.CreateMatrix
    Dim occ As ComponentOccurrence
    Set occ = oDef.Occurrences.Add("Path of part files\UCS part.ipt", occMatrix)
    Dim compDef As PartComponentDefinition
    Set compDef = occ.Definition
    Dim partUCS As UserCoordinateSystem
    Set partUCS = compDef.UserCoordinateSystems.Item(1)
    Dim oProxy As UserCoordinateSystemProxy
    Call occ.CreateGeometryProxy(partUCS, oProxy)
    Dim oMatrix As Matrix
    Set oMatrix = oProxy.Transformation
    Dim oUCSDef As UserCoordinateSystemDefinition
    Set oUCSDef = oDef.UserCoordinateSystems.CreateDefinition
    oUCSDef.Transformation = oMatrix
    Dim oUCS As UserCoordinateSystem
    Set oUCS = oDef.UserCoordinateSystems.Add(oUCSDef)
End Sub
Please feel free to contact if there is any queries.
If solves problem, click on "Accept as solution" / give a "Kudo".
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
Message 3 of 13
GeorgK
Hello @chandra.shekar.g,
is it possible to select the UCS directly? I have several parts with different UCS in each part.
Thank you for your help.
Georg
Message 4 of 13
chandra.shekar.g
Autodesk Support
Autodesk Support
Hi @GeorgK,
Try the following VBA code to select the UCS and create the same in AssemblyDocument.
Sub Main()
    Set oUCS = ThisApplication.CommandManager.Pick(kUserCoordinateSystemFilter, "Select UCS")
    Set oMatrix = oUCS.Transformation
    Dim copiedUCS As UserCoordinateSystem
    Set copiedUCS = oDef.UserCoordinateSystems.Add(oUCSDef)
End Sub
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Message 5 of 13
GeorgK
your code does not position the UCS in the assembly at the position where the part with the UCS is. The part includes the UCS.
Thank you Georg
Message 6 of 13
chandra.shekar.g
Autodesk Support
Autodesk Support
Hi @GeorgK
Try the following VBA code to copy UCS from part to assembly. Here, location of part occurrence plays important role in copying UCS. So, occurrence selection is required to copy UCS.
Sub Main()
    Set occ = ThisApplication.CommandManager.Pick(kAssemblyOccurrenceFilter, "Select occurrence from which UCS need to copy")
    Set occMatrix = occ.Transformation
    Call oMatrix.TransformBy(occMatrix)
End Sub
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Message 7 of 13
GeorgK
thank you very much. Now I understand the transformation. That's great. Is it possible to get the occurrence from the UCS by code?
Georg
Message 8 of 13
chandra.shekar.g
Autodesk Support
Autodesk Support
Hi @GeorgK,
Try the following VBA code which takes occurrence from UCS and copy UCS from part to assembly.
Sub Main()
    Dim occDef As ComponentDefinition
    Set occDef = oUCS.Parent
    For Each occ In oDef.Occurrences
        If occ.Definition Is occDef Then
    Next
    If occMatrix Is Nothing Then
        Debug.Print ("UCS occurrence not found")
    Else
End Sub
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Message 9 of 13
GeorgK
thank you very much. That saves me a lot of time.
Georg
Message 10 of 13
GeorgK
is it possible to get the UCS from a part in a subassembly? How do I transforme the matrix?
Thank you
Georg
Message 11 of 13
chandra.shekar.g
Autodesk Support
Autodesk Support
Hi @GeorgK,
You could try the following VBA code. Here, only part occurrences are considered.
Sub Main()
    For Each occ In oDef.Occurrences.AllLeafOccurrences
            Exit For
    Next
    Else
End Sub
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Message 12 of 13
GeorgK
thank you very much. That solves the problem.
Georg
Message 13 of 13
bt_cn
Hello, is it also possible to copy the UCS from an assembly to a subassembly?
