Simple iLogic Code Required !!!
Boggle88
Boggle88
Hi All,
A bit late but happy new year to you all.
I'm new to iLogic and are after some help or advice on writing codes in ilogic.
I work for a steel fabrication company and are after ways to increase productivity of detail drawings with our products.
I'm after some ilogic code for automatic dimension creation upon creating a base view in a drawing sheet along with automatic automated centrelines being added at the same time. please see attached photo showing the kind of dimensions and centrelines i intend to show if possible.
Please also find attached the ilogic form and parameters i've managed to create the drive the part.
Any help would be very much appreciated.
Dan
MechMachineMan
Automatic dimensioning isn't nearly as easy as you think.
What if there are 2+ dims along one edge?
What offset?
Where do you want the dim located?
How do you choose what edges to actually select, and how do you program this?
A way easier start is to use templates that are properly dimensioned, or to get your guys to model as they would dimension and pull model sketches into the drawing.
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Curtis_Waguespack
Hi Boggle88,
Have a look at this link. There is some information concerning automating drawing dimensions in this PDF.
https://forums.autodesk.com/autodesk/attachments/a​utodesk/120/58687/1/MA316-5,ConfiguratorTips.pdf
I hope this helps.
Curtis
