Sheet Name (number) Hide Page Prefix Zero
Reference Post: Sheet name (number)
Hi there,
I want to make something similar, but I cant "hide" de letter after the sheet number arrives to 10.
Example: I define 1 custom iProperty called "page" with number "0".
My First Page is: page<sheet number>
It will give me 01... OK! 😉 Then...
02, 03, 04, etc... 09... 010 ???
I want to hide the "page" custom iProperty when the number is < or = 10.
Im trying some codes but I cant reach it there 😞
help?
MANY THANKS 😉
tdant
I think I understand the problem. Create and iLogic rule and paste this code inside:
For Each sheet As Sheet In ThisApplication.ActiveDocument.Sheets
	Dim sheetNumArr As Array = Split(Sheet.Name, ":")
	If UBound(sheetNumArr) > 0 Then
		Dim rightMost As Integer = CInt(sheetNumArr(UBound(sheetNumArr)))
		If rightMost < 10 Then
			page = "0" & CStr(rightMost)
		Else
			page = CStr(rightMost)
		End If
	End If
Next
Click "Save and Run" and check the values of "page".
It works but the "iproperty" will be always 0...
I create new pages and then the page number 10, is "010"... I want to remove the "0" Robot wink
The only solution that I make is this:
Dim oSheet As Sheet
Dim SheetNumber As String
Dim List As New ArrayList
List.add("page")
oCustomPropertySet = ThisDoc.Document.PropertySets.Item("Inventor User Defined Properties")
i = 1
For Each oCustProp In oCustomPropertySet
	If List.Contains(oCustProp.Name) Then
		For Each oSheet In ThisApplication.ActiveDocument.Sheets
			SheetNumber  = Mid(oSheet.Name, InStr(1, oSheet.Name, ":") + 1)
				If SheetNumber < 10 Then
					ActiveSheet.TitleBlock = "Legenda_1_completa"
					iProperties.Value("Custom", "page") = "0"
				ElseIf SheetNumber >= 10 Then
					ActiveSheet.TitleBlock = "Legenda_2_completa"
				End If
			 i=1+1
		Next
						oDoc = ThisDoc.Document
						SheetNumber  = Mid(oDoc.ActiveSheet.Name, InStr(1, oDoc.ActiveSheet.Name, ":") + 1)
						End If
	End If
Next
But I use 2 Title Blocks... It seams that I have to make like this Smiley Frustrated
bradeneuropeArthur
Can you please make a screenshot of your drawing with the layout you need?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Curtis_Waguespack
Hi @Anonymous,
I'm not sure I understand the need for the number or how it will be used, but this simple ilogic rule increments the sheet name with a leading zero for all numbers less than 10.
I hope this helps.
Curtis
sPrefix = "Page "
i = 1
'rename all sheets incrementing suffix
sheet.Name = sPrefix + If(i < 10, "0" + CStr(i), CStr(i))
i = i + 1
Next
tdant
I think what the OP wants is to edit the sheet property "Sheet Number" to include leading zeroes up to 2 digits.
From what I can tell, the API doesn't allow access to that property, and anything that can be controlled via the API can't be effectively used in the title block. Unless there's a way to  use something like Drawing.AttributeSets in place of "sheet number" in the title block, I think we're out of luck.
