My First i Logic for Screw Conveyor (Help!!!)
mostafamahmoudseddek94
Hi every one
I am new to I logic and I am an internSmiley Happy, I have been asked to Automate the Design of Screw Conveyor Using CEMA Standard
the goal of the Task is to shorten the time needed for the Designer to model the Screw Conveyor
I have created a video to share what I have done  to gather professional people's opinions and thought
first,  I was thinking to make an i logic for every component individually then making i logic for the assembly file for the entire screw conveyor  but i have got troubles with constraints of the Assembly, fortunately, the i logic worked for the Assembly of the Element but not for the entire Design Although i have followed the Same procedure
you can find the video on this Link
Any help will be Appreciated
S_May
Hi @mostafamahmoudseddek94,
Welcome to the Forum, can you attach your attempt for us to try (PDF, BMP, IAM, IPT...)?
S_May
there is something else for you here  ilogic to test
S_May
S_May
here's another way, if you want to laser the spiral
