Create new alternative pages / sheet numbers
Hi there,
I will explain what I'm trying to do.
I need to get 2 types of pages, and numbering from is order. Im trying to do some coding but I cant reach it there.
Here is the problem:
* A3 format page = Sheet Numbers from 00 to 99.
* A4 format page = Sheet Numbers from 00 to 99.
BUT
When I put the "order" pages like, 3 pages A3 and then 1 A4, will appear the Sheet Number 03 in the "A4", and I want "00".
help? 😛
kelly.young has embedded your photo for clarity.
MechMachineMan
1. Forego the automated part and use prompted entry fields or
2. Use 2 different idws based on each format.
You're not gonna have much luck changing how the program is set up.
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Tomorrow I put here what I have already to see if someone can give more options...
