- Mute
- Permalink
- Report
I have a dialog that lets you format a part description for various different object types what we use.
I have about 9 combo boxes listing the available parameters in the dialog, though only 3 or 4 are used in a given part.
I have a single control that passes the info to inventor, creates, formats, exposes/exports and configures the parameter but doesn't show up in the descriptions. Other controls do exactly the same thing and work just fine. I have a feeling i'm missing something but do not see it.
Here's the code
'if angle is chosen If RadioButton3.Checked Then If AngBoxL1.Text = "" Or AngBoxL2.Text = "" Or AngBoxThk.Text = "" Or AngBoxLen.Text = "" Then MsgBox("You must fill in all values.", vbOKOnly) Else cnum = InStr(1, AngBoxL1.Text, "||", CompareMethod.Text) ln = Strings.Right(AngBoxL1.Text, Len(AngBoxL1.Text) - (cnum + 2)) 'MsgBox(desc) SetOther(ln, "LEG1") cnum = InStr(1, AngBoxL2.Text, "||", CompareMethod.Text) ln = Strings.Right(AngBoxL2.Text, Len(AngBoxL2.Text) - (cnum + 2)) 'MsgBox(desc) SetOther(ln, "LEG2") cnum = InStr(1, AngBoxThk.Text, "||", CompareMethod.Text) ln = Strings.Right(AngBoxThk.Text, Len(AngBoxThk.Text) - (cnum + 2)) 'MsgBox(desc) SetOther(ln, "THK") cnum = InStr(1, AngBoxLen.Text, "||", CompareMethod.Text) ln = Strings.Right(AngBoxLen.Text, Len(AngBoxLen.Text) - (cnum + 2)) 'MsgBox(desc) SetLen(ln) descr = "=ANG, <LEG1> x <LEG2> x <THK>" End If DelParam("WIDTH") DelParam("THK") End If Private Sub SetOther(ans As String, pm As String) Dim oPartDoc As PartDocument oPartDoc = g_inventorApplication.ActiveDocument 'MsgBox("1") Dim param As Object Try param = oPartDoc.ComponentDefinition.Parameters.UserParameters.Item(pm) 'MsgBox("2") Catch ex As Exception 'Dim newparam As UserParameter = oPartDoc.ComponentDefinition.Parameters.UserParameters.AddByValue("PL_LENGTH", ans, UnitsTypeEnum.kInchLengthUnits) Dim newparam As UserParameter = oPartDoc.ComponentDefinition.Parameters.UserParameters.AddByExpression(pm, ans, UnitsTypeEnum.kInchLengthUnits) 'MsgBox("3") End Try oPartDoc.ComponentDefinition.Parameters.UserParameters.Item(pm).Expression = ans oPartDoc.ComponentDefinition.Parameters.UserParameters.Item(pm).ExposedAsProperty = True 'MsgBox("4") oPartDoc.ComponentDefinition.Parameters.UserParameters.Item(pm).CustomPropertyFormat.Units = UnitsTypeEnum.kInchLengthUnits oPartDoc.ComponentDefinition.Parameters.UserParameters.Item(pm).CustomPropertyFormat.Precision = CustomPropertyPrecisionEnum.kSixteenthsFractionalLengthPrecision End Sub
The only parameter not working is THK. Like I said. It pulls the correct value, assigns it to the parameter, the export checkbox is checked, the internal custom formatting is correct. It just doesn't show in the description field. The field is set to =ANG, <LEG1> X <LEG2> X <THK>
Leg1 and 2 work just fine. I get a black for THK even though it's set correctly. If i open it's Custom Property format dialog and just hit OK without touching anything, it pops right into the description.
Any help would be appreciated.
