select case code related to a multibody solids visibility.
SpokenEarth
SpokenEarth
Hi forum, I'm having trouble with the select case code related to a multibody solids visibility.
I need a help with a code so when I'm fire from the Form the selected type, the feature in the model window is visible and other existing ones are not.
Thanks in advance for any help you can give.
bradeneuropeArthur
Can you explain a little more in detail what you try to do?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
SpokenEarth
When I select from the form1, under TYPE DIN32676SERIES2 STANDARD I want the solid body DIN32676 SERIES1 from the model browser to be invisible.
JelteDeJong
you could add this to your rule to hide a body
Dim nameOfBodyTohide = "DIN32676 SERIES1"
Dim doc As PartDocument = ThisDoc.Document
Dim def As PartComponentDefinition = doc.ComponentDefinition
Dim bodies As IEnumerable(Of SurfaceBody) = def.SurfaceBodies.Cast(Of SurfaceBody)
Dim body As SurfaceBody = bodies.
    Where(Function(b) b.Name.Equals(nameOfBodyTohide)).First()
body.Visible = False
Jelte de Jong
Blog: hjalte.nl - github.com
SpokenEarth
Thanks JelteDeJong, the code works fine, and almost accomplish what I need.
But how can automatically toggle the visibility?
For example, when am fire SIZE:DIN32676 SERIES2:STANDARD I would like to have the solid body DIN32676 SERIES1 invisible, and solid DIN32676 SERIES2 STANDARD visible
JelteDeJong
You can create a new rule and add this. with this rule the bodies get selected depending on the type
Public Sub Main()
	Select Case TYPE
		Case "DIN 32676 SERIES 1"
			setVisibility("DIN32676 SERIES1", True)
			setVisibility("DIN32676SERIES2 STANDARD" , False)
		Case "DIN 32676 SERIES 2 STANDARD"
			setVisibility("DIN32676 SERIES1", false)
			setVisibility("DIN32676SERIES2 STANDARD" , True)
		Case "...."
			' You might want to add more cases
	End Select
End Sub
Public Sub setVisibility(bodyName As String, visible As Boolean)
	    Where(Function(b) b.Name.Equals(bodyName)).First()
	body.Visible = visible
End Sub
Jelte de Jong
SpokenEarth
PERFECT!!!.....Thank you so much
You are always so you are very helpful.
Achilles
