Inventor.Circle vs Circle
nedeljko.sovljanski
Message 1 of 8
nedeljko.sovljanski
Does anybody know why declaration for Circle must be done with
Dim oCircle as Inventor.Circle
instead of
Dim oCircle as Circle?
Replies (7)
Message 2 of 8
bradeneuropeArthur
Because it is used in another object too.
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 3 of 8
nedeljko.sovljanski
I agree that is used in another object but I can not find in which.
Message 4 of 8
bradeneuropeArthur
I don't see a difference.
Could you share the code you have problems with?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 5 of 8
nedeljko.sovljanski
There is no particular problem but I am interested why in VBA it is necessary to use Inventor.Circle (and only for Circle) and in C# Inventor is redundant declaration.
For some newbies in macro writing in VBA it can be confusing, so I want someone to clarify.
Message 6 of 8
JelteDeJong
I could reproduce the "problem" but I could not find why. Usually, you need to add the namespace for an object type if the compiler does not know which namespace should be used. That implies that there is another namespace with the object "Circle" but I  could not find such namespace.
But if you are learning VBA then I would advise you to stop and start learning VB.net/iLogic. This is what Autodesk writes about VBA:
"For security reasons, the Microsoft VBA module is not included in the Inventor installer. It has a dependency on the Visual Studio 2010 (VC10) runtime, which Microsoft will not support after July 2020."
and
"As an alternative to VBA, consider using Inventor’s iLogic capability. It provides access to the Inventor API using VB.NET."
That sounds to me like the end of VBA and not something that I would put any effort in.
Jelte de Jong
Blog: hjalte.nl - github.com
Message 7 of 8
WCrihfield
I see that Access (Microsoft Access) has a Class called Report, and Circle is a Member (Sub) of that  (Access.Report.Circle())
Wesley Crihfield
(Not an Autodesk Employee)
Message 8 of 8
nedeljko.sovljanski
That is answer I am looking for. Thank you very much!
