Save As all occurrences from an assembly
JorisSteurs1246
JorisSteurs1246
The code below should make a copy of every part in an assembly and save it with a specific File name.
I think I have it all right up to the moment the part needs to be saved , I get an unknow error.
Any ideas what is going on here?
SyntaxEditor Code Snippet
  'check this file is an assembly
        Dim doc As Document = ThisApplication.ActiveDocument
        If doc.DocumentType = kPartDocumentObject Then
            MessageBox.Show("This rule can only be run in an assembly file!", "Cadline iLogic")
            Return
        End If
Dim newname As String
Dim compdef As ComponentDefinition
compdef = doc.ComponentDefinition
If (doc.documenttype = 12291) Then ' only do this for assembly or subassembly
 For Each occ In compdef.Occurrences
    If (occ.definition.type =83886592) Then ' only do this for part
         Dim oNewDoc As PartDocument
          oNewDoc = ThisApplication.Documents.Add(kPartDocumentObject, , False)
            occ.Name =  iProperties.Value(occ.Name,"Project", "Part Number")
             newname = iProperties.Value(occ.Name,"Project", "Part Number") & ".ipt"
            MessageBox.Show("I found variable: " & newname , "Info")
             ThisApplication.SilentOperation = True
               'oNewDoc = occ.Definiton.Document.SaveAs(newname, True)
            oNewDoc.SaveAs(newname, False)
            ThisApplication.SilentOperation = False
    End If
 Next
End If
Jef_E
You are making a new empty document? And then saving it as another empty document?
Please kudo if this post was helpfull
Please accept as solution if your problem was solved
Inventor 2014 SP2
JorisSteurs1246
you are right , right now a new empty document is created,
but I don't manage to save it with a new name.
It goes wrong at this line
my final goal is to save out an occurrence from the  assembly with another filename.
MechMachineMan
If you are trying to make a smart way to rename parts, I hope you realize that without replacing references within your code, your file references will be all messed up.
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
JorisSteurs1246
The command I use now manually now  you find under the productivity tab, called "save and Replace Component".
The goal is get some code together that loops trough the assembly and saves every part by its partnumber.
If I do this manually with the "save and Replace Component" all the references and constrains are still OK , so I assume it will not be different when using iLogic?
