ilogic to read different sheets/tabs in excel
I was wondering if anyone knows a code or a way to get inventor to recognize which sheets/tabs to read points from excel without any parameters in that sketch. I've been helped with this code
GoExcel.CellValue("filename.xls", "Sheet1", "A2")
but its not what I am trying to do.. I need it to let the user pick which excel file to use and which sheet/tabs to read the x-y coordinates from. The command I have is this
Sub Main()
   ' Get the CommandManager object.
    Dim oCommandMgr As CommandManager
    oCommandMgr = ThisApplication.CommandManager
    ' Get control definition for the line command.
    Dim oControlDef As ControlDefinition
    oControlDef = oCommandMgr.ControlDefinitions.Item( _
                                                 "SCxImportPointsCmd")
    ' Execute the command.
    Call oControlDef.Execute
End Sub
now the question is how do i get it to read like sheet 2 instead of sheet 1? keep in mind the sketch is just importing in points.. it has no parameters or anything to let inventor know to replace a number or where the points are at. I can't use parameters because the points are going to be clear each time a new x-y coordinates are being generated.
Curtis_Waguespack
Hi lle5956,
I replied to the original thread here:
http://forums.autodesk.com/t5/inventor-forum/ilogic-code-to-read-a-specific-excel-sheet-in-a-workboo...
I hope this helps.
Curtis
