Ribbon data saved
Ribbon data saved
FeelGoodGirl
Ribbon data saved
FeelGoodGirl
I am in the process of making a ribbon for my work. When it is finished I want to share it with colleagues. Now I know that I that I can export the ribbon and the other can import it. I want to skip this step and immediately edit the file where inventor stores the ribbon data. However, I cannot find the location where Inventor gets this data from.
Does anyone know where this is or how I can find it?
Tiffany_Hayden_
Are you talking about creating a ribbon through a custom Add-in or just through Inventor itself?
Tiffany Hayden
bradeneuropeArthur
It is stored here:
C:\Users\.....\AppData\Local\Autodesk\Inventor ###\Preferences
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Tiffany_Hayden_
@bradeneuropeArthur Cool!
Tiffany Hayden
FeelGoodGirl
Thank you for your response. I already had that suspicion, only then I don't get it.
If I modify something in the ribbon, no file is updated there. So if I e.g. add a macro to the ribbon, the 'date modified' all remain the same...
