iLogic: Adding labels to part views from the parent Assembly drawing partsList.
shizahkhalid
shizahkhalid
I'm generating single view part drawings for each part in an assembly and then adding labels to each view. The labels contain corresponding QTY, ITEM, and DESCRIPTION values from the partsList generated on the Assembly drawing. There seems to be an issue with the way I'm populating the arrays, and I am getting an "index is out or range" error. i.e., the number of labels generated is less than the number of drawing views. I can't for the life of me figure out why. Would really appreciate if someone could point out the issue.
   Sub main()
        Dim SelSet As SelectSet = ThisDrawing.Document.SelectSet
        If SelSet.Count = 0 Then
            MsgBox("You need to pre-select a drawing view before running this rule. Exiting.", , "")
            Exit Sub
        Dim oView As DrawingView = SelSet.Item(1)
        If oView Is Nothing Then Exit Sub
        Dim oDrawDoc As DrawingDocument
        oDrawDoc = ThisApplication.ActiveDocument
        Dim OrgSheet As Sheet
        OrgSheet = oDrawDoc.ActiveSheet
        Dim oPartslist As PartsList =  OrgSheet.PartsLists.Item(1)
        oPartsList.Style = oDrawDoc.StylesManager.PartsListStyles.Item("ProwayTemp")
        'get the view's model document
        Dim oDoc As Document = oView.ReferencedDocumentDescriptor.ReferencedDocument
        Dim oDrgDoc As DrawingDocument
        oDrgDoc = ThisApplication.ActiveDocument
        Dim PartDoc as Document
        Dim initialX as Integer
        Dim oSheet As Sheet
        oSheet = oDrgDoc.Sheets.Add()
        oSheet.Name = oDoc.DisplayName
        Dim ItemList As New ArrayList
        Dim QtyList As New ArrayList
        Dim DescList As New ArrayList
        initialX = 4
        For Each PartDoc in oDoc.AllReferencedDocuments
            If PartDoc.DocumentType = kPartDocumentObject Then
                Call CreateDrawing(PartDoc, initialX, oSheet)
                initialX = initialX + 10
                no_of_part_docs += 1
                'get iproperty to compare with partslist
                oPartProp = PartDoc.PropertySets.Item("Design Tracking Properties").Item("Part Number").Value
                For Each oRow As PartsListRow In oPartslist.PartsListRows
                    oPartValue = oRow.Item("PART NUMBER").Value
                    If oPartValue = oPartProp Then
                        Dim itemValue As String = oRow.Item("ITEM").Value
                        Dim qtyValue As String = oRow.Item("QTY").Value
                        Dim descValue As String = oRow.Item("DESCRIPTION").Value
                        ItemList.Add(itemValue)
                        QtyList.Add(qtyValue)
                        DescList.Add(descValue)
                Next
        Next
        oPartsList.Style = oDrawDoc.StylesManager.PartsListStyles.Item("Proway")
        Dim descListString As String
        descListString = "ItemList contents:" & vbCrLf
        ' Iterate through each item in the DescList
        For Each descValue As String In DescList
            descListString = descListString & descValue & vbCrLf
        Next
        ' Display the itemListString in a message box
        MsgBox(descListString)
        If no_of_part_docs = 0
        MsgBox("Please select an assembly to run this function.")
    'ArrangeViews(oSheet, PartDoc)
    'iLogicVb.RunExternalRule("ArrangeViews_StNo")
    iLogicVb.RunExternalRule("DimMasterRuleFinal")
    Dim _view As DrawingView
    'Add Properties in the Label
    oSheet.Activate()
    Dim ItemIndex As Integer
    ItemIndex = 0
    For Each view In oSheet.DrawingViews
        _view = view
        _view.ShowLabel = True
        oDocName = _view.ReferencedDocumentDescriptor.ReferencedDocument.DisplayName
        'MsgBox(oDocName)
            If _view IsNot Nothing Then
                'get the properties from the model
                'oDescription = iProperties.Value(oDocName, "Project", "Description")
                'modify the view label as needed
                _view.Label.FormattedText = "ITEM " & ItemList(ItemIndex) & vbCrLf & DescList(ItemIndex) & vbCrLf & QtyList(ItemIndex) & " REQUIRED"
                Dim PT1 As Point2d
                PT10 = ThisApplication.TransientGeometry.CreatePoint2d
                PT10.X = _view.Center.X
                PT10.Y = _view.Top - _view.Height - 1
                _view.Label.Position = PT10
            ItemIndex += 1
    Next
    End Sub
Sub CreateDrawing(oDoc As PartDocument, initialX As Integer, oSheet As Sheet)
    '------ Locating the Template ------'
    'strLocation = ThisApplication.FileOptions.TemplatesPath
    'oDrgDoc = ThisApplication.Documents.Add(kDrawingDocumentObject, strLocation & "CPT-DRAWING-TEMPLATE.idw")
    'Set the sheet size
    ActiveSheet.ChangeSize("A3", moveBorderItems := True)
    'Add / Change the drawing border
    ActiveSheet.Border = "Default Border"
    ActiveSheet.SetTitleBlock("PW")
	' Get the TransientBRep and TransientGeometry objects.
	Dim transBRep As TransientBRep = ThisApplication.TransientBRep
	Dim transGeom As TransientGeometry = ThisApplication.TransientGeometry
	' Combine all bodies in Part into a single transient Surface Body.
	Dim combinedBodies As SurfaceBody = Nothing
	For Each surfBody As SurfaceBody In oDoc.ComponentDefinition.SurfaceBodies
		If combinedBodies Is Nothing Then
			combinedBodies = transBRep.Copy(surfBody)
		Else
			transBRep.DoBoolean(combinedBodies, surfBody, BooleanTypeEnum.kBooleanTypeUnion)
	Next
	' Get the oriented mininum range box of all bodies in Part.
	' NOTE: "OrientedMinimumRangeBox" was added in Inventor 2020.3/2021.
	Dim minBox As OrientedBox = combinedBodies.OrientedMinimumRangeBox
	' Get length of each side of mininum range box.
	Dim dir1 As Double = minBox.DirectionOne.Length
	Dim dir2 As Double = minBox.DirectionTwo.Length
	Dim dir3 As Double = minBox.DirectionThree.Length
	' Convert lengths to document's length units.
	Dim uom As UnitsOfMeasure = oDoc.UnitsOfMeasure
	dir1 = uom.ConvertUnits(dir1, "cm", uom.LengthUnits)
	dir2 = uom.ConvertUnits(dir2, "cm", uom.LengthUnits)
	dir3 = uom.ConvertUnits(dir3, "cm", uom.LengthUnits)
	' Sort lengths from smallest to largest.
	Dim lengths As New List(Of Double) From {dir1, dir2, dir3}
	lengths.Sort
	Dim minLength As Double = lengths(0)
	Dim midLength As Double = lengths(1)
	Dim maxLength As Double = lengths(2)
	Dim desiredWidthOnSheet As Double
    Dim desiredHeightOnSheet As Double
    desiredWidthOnSheet = (oSheet.Width / 2) + 10 ' Adjust as needed
    desiredHeightOnSheet = (oSheet.Height / 2) + 10 ' Adjust as needed
    ' Calculate the scale factor based on the part dimensions and desired size on the sheet
    Dim scaleFactor As Double
    scaleFactor = Min(desiredWidthOnSheet*5 / partWidth, desiredHeightOnSheet*5 / maxLength)
    Dim offset as Integer
    offset = 3
    'Location of the Views
    Dim oPoint2 As Point2d
    oPoint2 = ThisApplication.TransientGeometry.CreatePoint2d(initialX, (oSheet.Height/1.5) + offset)
    Dim oView1 As DrawingView
    oView1 = oSheet.DrawingViews.AddBaseView(oDoc, oPoint2, (scaleFactor), kLeftViewOrientation, kHiddenLineDrawingViewStyle)
End Sub
A.Acheson
Hi @shizahkhalid
I didn't have time to check but I would check if your array indexes actually produce meaningfully values on this line here. Use a message box or logger line and make sure you don't exceed the array count. You can perhaps put a try catch statement around any problem areas and narrow down the line.
Regards
Alan
shizahkhalid
Thanks for you reply. My code works perfectly for all assemblies except those containing subassemblies. Though it creates drawing views of all the parts, it does not create labels for all of them. Do you know how I can treat the subassembly parts differently so that labels are created for its parts too?
A.Acheson
Your not getting labels for sub assemblies because your looping through top level assemblies only in the partlist.
 You need to check the row referenced doc is an assembly and then expand that assembly row to expose the children beneath. Equivalent of pressing the plus sign in the partlist manually.
Syntax
PartsListRow.ReferencedRows() As ObjectsEnumerator
See full method to expose document reference of partlist row here.
Syntax
PartsListRow.Expanded() As Boolean
Regards
Alan
