Referencing custom iProperties created by Frame Generator
Raider_71
Raider_71
Hi I am having difficulty referencing the Custom iProperties created by Frame Generator. I have written a small VB.net application to extract the custom iPorpoeties and it works for normal custom props but just not the ones created by F generator. I am trying to extract the values of CUTDETAIL1 and CUTDETAIL2 but when I try and reference them by name it does not work. If I run a For Each loop then I can see the name for these properties are in fact not as presented in the iProperties dialogue but something completely different.
CUTDETAIL1 was presented as something like "B67C9A1B-478A-9058-CRG34J6LD7B" for instance.
For each part I have checked it looks like CUTDETAIL1 and CUTDETAIL2 are presented by a unique number like the one above.
Please see sample part attached.
How can I pick up the value of these types of parameters?
Thanks!
bradeneuropeArthur
Please upload your code so I can investigate what is wrong.
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Raider_71
Hi @bradeneuropeArthur
Thanks for the reply. Please see simplified solution attached.
bradeneuropeArthur
Found:
    Private Sub Button1_Click(sender As Object, e As EventArgs) Handles Button1.Click
        If oApp.Documents.Count < 1 Then
            Exit Sub
        End If
        Dim oDoc As Inventor.Document = oApp.ActiveDocument
        Dim oCustomiProps As Inventor.PropertySet = oDoc.PropertySets.Item("{D5CDD505-2E9C-101B-9397-08002B2CF9AE}")
        For Each oCustProp As Inventor.Property In oCustomiProps
            'MessageBox.Show(oCustProp.PropId & ":" & oCustProp.Value.ToString & vbCrLf & oCustProp.Name & ":" & oCustProp.Value.ToString)
            MessageBox.Show(oCustProp.DisplayName & " :  " & oCustProp.Value.ToString)
        Next
    End Sub
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Raider_71
Ouch! Ok that was a rookie mistake... Man Very Happy
Thanks for the prompt reply and assistance!!!
bradeneuropeArthur
Could you please Mark as solved for administrative reasons. Thank you.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
