Referenced File Descriptor Fails
dbrblg
dbrblg
I am using the following code to traverse an assembly and print out the parts within it:
Public Sub TraverseAssemblySample()
    ' Get the active assembly.
    Dim fso As New FileSystemObject
    Dim OApp As Inventor.Application
    Set OApp = GetObject(, "Inventor.Application")
    Dim oAsmDoc As Inventor.AssemblyDocument
    Set oAsmDoc = OApp.ActiveDocument
    Debug.Print oAsmDoc.DisplayName
    ' Call the function that does the recursion.
    Call TraverseAssembly(oAsmDoc.ComponentDefinition.Occurrences, 1)
End Sub
Private Sub TraverseAssembly(Occurrences As ComponentOccurrences, Level As Integer)
    ' Iterate through all of the occurrence in this collection.  This
    ' represents the occurrences at the top level of an assembly.
    Dim oOcc As ComponentOccurrence
    For Each oOcc In Occurrences
        ' Print the name of the current occurrence.
        Debug.Print Space(Level * 3) & oOcc.DefinitionReference.ReferencedFileDescriptor.DisplayName
        ' Check to see if this occurrence represents a subassembly
        ' and recursively call this function to traverse through it.
        If oOcc.DefinitionDocumentType = kAssemblyDocumentObject Then
            Call TraverseAssembly(oOcc.SubOccurrences, Level + 1)
    Next
End Sub
 The problem I have is the ReferencedFileDescriptor fails with the following message:
This error occurs here:
This is code which is from the Autodesk site but the worrying thing is this issue is completely random.  It will work without issues on an assembly then another time I will get this error.  Each time I get the error, it is with a different part file!!  I get the error on different parts on different assemblies at different times.
Has anyone encountered this?
MechMachineMan
The way you are accessing referenced file descriptor is wrong according to the Programming Help.
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
dbrblg
Ah, that's interesting....I got this sample from the Autodesk website Smiley Indifferent
I don't have any samples for use; which programming help is to which you refer?  I would like to understand its correct use.
MechMachineMan
C:\Program Files\Autodesk\Inventor 2014\Local Help\admapi_18_0.chm
or the one found by clicking the question mark in the top right of inventor and selecting "Programming Help"
Justin K
dbrblg
I've looked in the help files, as suggested however the FileReferenceSampe also does not work.  This time with this error:
MechMachineMan
oModelName = oSheet.DrawingViews.Item(1).ReferencedDocumentDescriptor.ReferencedDocument.FullDocumentName
Just change oSheet.DrawingViews.Item(1) to be the occurrence object instead.
This is a working chunk from one of my programs that I have written.
Justin K
