ilogic Help Please BOM Work Features
I have the following code and use them with an event Trigger before save.
I am wondering if anyone can help me piece together ilogic that I can do the Other to Both Parts & Assemblies regardless of the BOM
So what I need is ALL the visiblity of WORK FEATURES OFF and 'ZOOM to EXTENTS and BOM REORDER BY PARTNUMBER
_____________________________________________________
i = MessageBox.Show("Reorder the BOM by PartNumber", "My iLogic Dialog", MessageBoxButtons.OK, MessageBoxIcon.Hand, MessageBoxDefaultButton.Button1)
'sort parts list
On Error Resume Next
Dim oDrawDoc As DrawingDocument
oDrawDoc = ThisApplication.ActiveDocument
Dim oPartsList1 As PartsList
oPartsList1 = oDrawDoc.ActiveSheet.PartsLists.Item(1)
'If oPartsList1 Is Nothing Then Resume Next
oPartsList1.Sort("PART NUMBER")
oPartsList1.Renumber
'zoom Extents Code
ThisApplication.CommandManager.ControlDefinitions.Item("AppIsometricViewCmd").Execute
'BOM ReOrder
MechMachineMan
Cannot access camera directly. Must use oCam= or something similiar
Dim oCam As Camera
'For the active document
oCam = ThisApplication.ActiveView.Camera
With oCam
.ViewOrientationType()=ViewOrientationTypeEnum.kIsoTopRightViewOrientation
.Fit
.Apply
End With
ThisApplication.ActiveView.Fit(True)
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
The code that i have listed between the breaks work by them selves for Reordering the BOM by PartNumber and for Zoom Extents I would like to combine them and also add code to have all Work Features turned off. Than I would add that to a an event trigger before save.
